problem med uppdatering
42 svar · 698 visningar · startad av andreas_lindh
andreas_lindhMedlem sedan jan. 20011 140 inlägg
Har denna koden
Sub datagrid1_update(sender As Object, E As datagridCommandEventargs)
			Dim tblaga as textbox=  E.Item.FindControl("tblag_a")
			Dim laga As String = tblaga.Text
			Dim tblagb as textbox=  E.Item.FindControl("tblag_b")
			Dim lagb As String = tblagb.Text
			Dim tbresultata as textbox=  E.Item.FindControl("tbresultata")
			Dim resultata As String = tbresultata.Text
			Dim tbresultatb as textbox=  E.Item.FindControl("tbresultatb")
			Dim resultatb As String = tbresultatb.Text
			Dim tbtid as textbox=  E.Item.FindControl("tbtid")
			Dim tid As String = tbtid.Text
			Dim tbdag as textbox=  E.Item.FindControl("tbdag")
			Dim dag As String = tbdag.Text
			dim id as integer = Datagrid1.DataKeys(CType(E.Item.ItemIndex, Integer))
			dim objcmd1 as new oledbcommand _
             ("select id, lagid_a, lagid_b, resultat_a, resultat_b from matcher where id=" + id +"", objconn)
			dim dr as OleDbdatareader
			objconn.open
			dr =objcmd1.executereader
			while dr.read()
				dim lag1 as integer = dr("lagid_a")
				dim lag2 as integer = dr("lagid_b")
					if dr("resultat_a") =resultata and dr("resultat_b") = resultatb then
						dim strsql as string ="update matcher set dag='" + dag +"',tid='" + tid +"', lagid_a="+ lag1 +",lagid_b="+ lag2 +" where id=" +id +""
						dim objcmd as new oledbcommand(strsql, objconn)
						objcmd.connection.open()
						objcmd.executenonquery()
						objcmd.connection.close()
						datagrid1.Edititemindex =-1
						datagrid1.databind()
						dim strsql1 as string ="update matcher set Resultat_a=" + resultata +",Resultat_b=" + resultatb +", uppdaterad=true where id=" +id +""
						dim objcmd2 as new oledbcommand(strsql1, objconn)
						objcmd2.connection.open()
						objcmd2.executenonquery()
						objcmd2.connection.close()
			end while
			objconn.close
    End Sub
Får detta felmeddalndet:
System.FormatException: Input string was not in a correct format
renholmMedlem sedan apr. 20012 266 inlägg
Vilken rad?
EkströmMedlem sedan feb. 20022 594 inlägg
Dessa prylar:
gör ingenting i slutet på dina SQL-satser. Misstänker dock att det inte har något med problemet att göra.
rad 52
PMedlem sedan jan. 20012 204 inlägg
vet inte om det är hela koden du visar men jag hittar inte att du dimar objconn någonstans
Objconn finns med längr upp i koden så det är inte det som är fel.
tar jag bort if satsen och bara gör en vanlig update fungerar det.
problemet verkar ligga i where id=" + id +" för när jag skriver where id=1 fungerar det.
Dessa prylar:
Jag får felmeddelande om jag tar bort dom
fredrikMedlem sedan dec. 19991 072 inlägg
Prova att bygga ihop strängen med string.format istället:
Dim strsql1 As String = String.Format("update matcher set Resultat_a={0},Resultat_b={1},uppdaterad=true where id={2}", resultata, resultatb, id)
Bör ju bli samma resultat, men kolla annars vad strSql1 innehåller och om den ser rätt ut.
Prova isf. att köra resultatet direkt i QA (för SQLserver) eller som en fråga i Access.
Provade att köra en fråga i access och då fungerade det.
Problemet är att den klagar på alla rader där jag har med where id=" + id +"
Detta fungerade.
Kan jag göra likadant med en select?
NETworkMedlem sedan juni 20011 732 inlägg
Japp, det går bra! Jag tycker dock det verkar konstigt att det inte fungerar på det andra sättet också. Exakt vad innehåller "id", har du provat att skriva ut det? Är det inte möjligt att den skriver ut ett id som inte finns? Jag menar, om det fungerar om du skriver id=1 men inte id=" + id så MÅSTE det vara något lustigt med variabeln...
När jag skriver ut id med response.write får jag ett id som finns i databasen.
Hur ska select satsen se ut med string.format ?
I ditt fall typ:
Dim strSQL as String= String.Format("select id, lagid_a, lagid_b, resultat_a, resultat_b from matcher where id={0}", id)
Se tidigare inlägg ang. string.format:
http://www.webforum.nu/showthread.php?s=&postid=423650#post423650
Nu har jag ett nytt problem.
Felmeddelande:
System.InvalidOperationException: The connection is already Open (state=Open, Fetching).
På line 77
		dim m_id as integer = Datagrid1.DataKeys(CType(E.Item.ItemIndex, Integer))
		'dim objcmd1 as new oledbcommand("select * from matcher where id="+ m_id +"", objconn)
		Dim strSQL as String= String.Format("select id, lagid_a, lagid_b, resultat_a, resultat_b, dag, tid,slutspel, uppdaterat_resultat from matcher where id={0}", m_id)
		response.write(strSQL)
		dim objcmd1 as new oledbcommand(strsql, objconn)
		objconn.open
			while dr.read()
					if dr("slutspel") = true then
						'Uppdatera bara spelschemat
						Dim strsql3 As String = String.Format("update matcher set lagid_a={0},lagid_b={1},resultat_a{2},resultat_b{3}, dag={4},tid={5} where id={6}", lag1, lag2, resultata, resultatb, dag, tid, m_id)
						dim objcmd3 as new oledbcommand(strsql, objconn)
						objcmd3.connection.open()
						objcmd3.executenonquery()
						objcmd3.connection.close()
							Dim strsql4 As String = String.Format("update matcher set lagid_a={0},lagid_b={1},dag={2},tid={3} where id={4}", laga, lagb, dag, tid, m_id)
							dim objcmd4 as new oledbcommand(strsql4, objconn)
							[b]objcmd4.connection.open()[/b]
						objcmd4.executenonquery()
							objcmd4.connection.close()
							if dr("uppdaterat_resultat") = true then
								dim mala as integer = dr("resultat_a")
								dim malb as integer = dr("resultat_b")
								'Ta bort gammlat resultat i tabell
								'Innehåll från upp_tabb2.asp
									if mala > malb then
									elseif mala = malb then
								'Lägg till nytt resultat i tabell
								'Innehåll från upp_tabb.asp
									if mala > malb then
								' Uppdatera spelschema
								Dim strsql1 As String = String.Format("update matcher set Resultat_a={0},Resultat_b={1},uppdaterad=true where id={2}", resultata, resultatb, m_id)
								dim mala as string = resultata
								dim malb as string = resultatb
									if mala > malb then
								Dim strsql5 As String = String.Format("update matcher set Resultat_a={0},Resultat_b={1},uppdaterad=true where id={2}", resultata, resultatb, m_id)
								dim objcmd5 as new oledbcommand(strsql5, objconn)
								objcmd5.connection.open()
								objcmd5.executenonquery()
								objcmd5.connection.close()
			end while
		objconn.close
    End Sub
Rad 77 är den fetstil
Eftersom du redan öppnat "objconn" högre upp behöver du inte öppna den igen. Då du deklarerar "objcmd4" med "objconn" i kontruktorn så jobbar den redan mot en öppen Connection.
Du kan alltså ta bort den raden.
Får ett nytt felmeddlande när jag tar bort den raden
System.InvalidOperationException: There is already an open DataReader associated with this Connection which must be closed first.
på rad 77
Aha...läste inte din kod så noga innan...
Om du har en DataReader "igång" med ett visst Connection-objekt så kan du inte använda det objektet till något annat så länge DataReadern är öppen.
Du får helt enkelt skapa en Connection till eller se till att stänga DataReadern.
Du kan på ett enkelt sätt skapa en ny connection med:
Dim objcmd4 As New OleDb.OleDbCommand(strsql4, New SqlClient.SqlConnection(objconn.ConnectionString))
Tycker det låter lite lurigt att det är så här..men då jag själv stött på problemet och inte hittat nån väg runt antar jag att det är så...
...men om nån har nån lösning så posta gärna!
låter lit e onödigt att skapa en ny anslutning varje gång.
Borde gå att lösa på något annat sätt
Fungerar det med access också?
Nu har jag löst problemet med anslutningen.
Gjorde så här
Dim strsql4 As String = String.Format("update matcher set lagid_a={0},lagid_b={1},dag={2},match_nummer={3}, tid={4} where id={5}", lag1, lag2, dag, match_nummer,tid, m_id)
							response.write(strsql4)
							objconn.close
							objconn.open
Nytt problem.
System.Data.OleDb.OleDbException: Syntaxfel (operator saknas) i frågeuttrycket '17:30'.
På rad 81
rad 81:objcmd4.executenonquery()
