Jag har ett litet bild-script som funkar fint. Dock fungerar det ej om jag vill byta ut knapparna mot bilder. Nån som vet hur man ska göra?
<form name="SlideShow">
<table>
<tr>
<td colspan=2><img name="Screen" width=200 height=150></td>
</tr>
<tr>
<td><input type="button" name="Previous"
value=" << "
onClick="ShowSlide(-1)"></td>
<td align="right"><input type="button" name="Next"
value=" >> " onClick="ShowSlide(1)"></td>
</table>
Så här ser själva scriptet ut...mycket kod...
//Preloaded slideshow script- By Jason Moon
//For this script and more
//Visit [url]http://www.dynamicdrive.com[/url]
// PUT THE URL'S OF YOUR IMAGES INTO THIS ARRAY...
var Slides = new Array('img/ljungby_folk.gif','img/Carolina_Mattias.jpg','img/Carolina_Mattias.jpg');
// DO NOT EDIT BELOW THIS LINE!
function CacheImage(ImageSource) { // TURNS THE STRING INTO AN IMAGE OBJECT
var ImageObject = new Image();
ImageObject.src = ImageSource;
return ImageObject;
function ShowSlide(Direction) {
if (SlideReady) {
NextSlide = CurrentSlide + Direction;
// THIS WILL DISABLE THE BUTTONS (IE-ONLY)
document.SlideShow.Previous.disabled = (NextSlide == 0);
document.SlideShow.Next.disabled = (NextSlide ==
(Slides.length-1));
if ((NextSlide >= 0) && (NextSlide < Slides.length)) {
document.images['Screen'].src = Slides[NextSlide].src;
CurrentSlide = NextSlide++;
Message = 'Picture ' + (CurrentSlide+1) + ' of ' +
Slides.length;
self.defaultStatus = Message;
if (Direction == 1) CacheNextSlide();
return true;
function Download() {
if (Slides[NextSlide].complete) {
SlideReady = true;
else setTimeout("Download()", 100); // CHECKS DOWNLOAD STATUS EVERY 100 MS
return true;
function CacheNextSlide() {
if ((NextSlide < Slides.length) && (typeof Slides[NextSlide] ==
'string'))
{ // ONLY CACHES THE IMAGES ONCE
SlideReady = false;
self.defaultStatus = 'Downloading next picture...';
Slides[NextSlide] = CacheImage(Slides[NextSlide]);
Download();
return true;
function StartSlideShow() {
CurrentSlide = -1;
Slides[0] = CacheImage(Slides[0]);
SlideReady = true;
ShowSlide(1);
Ok, strunt i knapparna, de får vara. Men nu ett nytt problem..hur får jag bilderna länkade?
solbulleMedlem sedan mars 20015 287 inlägg Detta borde fungera:
var slidelinks=new Array("http://www.dynamicdrive.com","http://wsabstract.com","http://www.geocities.com")
var whichlink=0
return ImageObject;
if (SlideReady) {
(Slides.length-1));
Slides.length;
whichlink=NextSlide-1;
return true;
SlideReady = true;
return true;
'string'))
SlideReady = false;
Download();
return true;
CurrentSlide = -1;
SlideReady = true;
ShowSlide(1);
function link() {
window.location=slidelinks[whichlink]
<body onLoad="StartSlideShow()">
<table>
<tr>
<td colspan=2><a href><img name="Screen" width=200 height=150 onclick="link()"></A></td>
</tr>
<tr>
value=" << "
</table>
solbulleMedlem sedan mars 20015 287 inlägg Vill du ha bilder får du ändra till:
<input type="image" name="Previous" SRC="leftarrow.gif" onClick="ShowSlide(-1)">
å liknande på den andra, samt att du måste nog utkommentera eller ta bort raderna:
document.SlideShow.Next.disabled = (NextSlide == (Slides.length-1));
Tusen tack, båda dina lösningar funkade fint!!
Kortvarig lycka..nu strular det. Länkarna funkar bra men knappbilderna vill inte. Inget händer när jag klickar på pilarna, den första bilden laddas bara om igen :(. Nån idé om vad felet kan vara? Synd för det såg så snyggt ut med andra knapper.
