Uppdatera två frames-inte så lätt i detta fall
JavaScriptur Javascript
2 svar · 188 visningar · startad av soffan76
Medlem sedan maj 2001684 inlägg
Hej alla!
Jag har ett problem. Jag har hittat ett skript med en s.k. folddown-meny. Jag vill nu kunna uppdatera två frames när man klickar på en av undermenyerna. Jag kan inte få till det. Kan nån hjälpa vore jag mycket tacksam.
// **                                SETTINGS                                 **
// 'linka' use this if part of the URL is the same in ALL the links
// In this example all the files are in a subfolder called 'pages'
linka='pages/';
// the filename of the page the menu appears in eg 'menu.html'
thisPage='menu.html';
// Do you want to use images for the category bullets?
// If so then specify the path to your images folder from the menu page
imgPath='images/';
// do you want to use images for the category bullets?
lev1img='yes';					// insert yes or no
// give image names and dimensions
lev1OpName='open.gif';			// open image name
lev1OpHeight='10';				// image height
lev1OpWidth='10';				// image width
lev1ClosName='closed.gif';		// closed image name
lev1ClosHeight='10';			// image height
lev1ClosWidth='10';				// image width
// do you want to use images for the sub-category bullets?
lev2img='yes';		// insert yes or no
lev2Name='bullet.gif';			// image name
lev2Height='10';				// image height
lev2Width='16';					// image width
// do you want to use a text character for the sub-category bullets?
lev2Char='no';		// insert yes or no
// set bullet character for level 2 bullets
bullet = '› ';
// base target - the frame that the links are targetting
base = 'main';
// **                             END OF SETTINGS                             **
// pulls 'page' variable out of URL - do not alter
	var x = 0
	page = location.search.substr(1).split("?")
	for (x=0;x<=page.length;x++) {
		eval(page)
page = escape(page);
page = page.slice(7);
// do not alter this bit
function subMenu(name,linkb) {
 this.name = name;
 this.linkb = linkb;
document.write('<BASE target="' + base + '">');
 function load2(URL1,URL2)
	parent.main.location.href=URL1;
	parent.top.location.href=URL2;
// **                             BUILD MENU DATA                             **
// Civils & Drainage Menu
if (page=='civ') {
thisMenu = new Array();
thisMenu[0] = new subMenu('test1','koncernen.htm');
thisMenu[1] = new subMenu('test2','below.html');
thisMenu[2] = new subMenu('test3','paving.html');
// Clothing Menu
if (page=='cloth') {
thisMenu[0] = new subMenu('Hats',"javascript:load2('test1.htm', 'test2.htm')");
thisMenu[1] = new subMenu('Gloves','gloves.html');
thisMenu[2] = new subMenu('Coats','coats.html');
"Varför är det alltid så mycket månad kvar i slutet av pengarna?"
<select name="foo" onChange="var ua=this[this.selectedIndex].value.split(':'); parent.framea.location.href=ua[0]; parent.frameb.location.href=ua[1];">
<option value="sida1.html:sida2.html">Sida 1 och 2</option>
<option value="sida3.html:sida4.html">Sida 3 och 4</option>
</select>
/ J
OK, tack!
Ska testa!
134 ms totalt · 3 externa anrop · v20260731065814-full.4bcf49fe
