Shirow
ctrl+V - leken
4 904 svar · 817 366 visningar · startad av M.Cheraghi · sida 108 av 246
Frågan, av M.Cheraghi
Jahapp! Det kan inte vara så himla svårt eller hur? Leken går altså ut på att man ska ctrl-v'a ut det man har lagrat, i \[ citat \] taggen! Om man nu inte har något i ctrl-v så låter man helt enkelt innehållet i \[ citat \] taggen vara tomt. :) Man skall heller således inte fuska och hitta något roligt att klistra in. Man tar det man har helt enkelt. Ibland kanske det kommer något roligt, andra gå
Läs frågan i sin helhet →// Setting the Content-Type header with charset
header('Content-Type: text/html; charset=utf-8');
Replication Types
Microsoft SQL Server 7.0/2000 supports the following replication types:
Snapshot
Transactional
Merge
Snapshot replication is the simplest type of replication. With this kind of replication, all replicated data (replica) will be copied from the Publisher database to the Subscriber's/Subscribers' database(s) on a periodic basis. Snapshot replication is best used as a method for replicating data that changes infrequently and when the size of replicated data is not very large.With Transactional replication, SQL Server captures all changes that were made in an article and stores INSERT, UPDATE, and DELETE statements in the distribution database. These changes are then sent to subscribers from the distribution database and applied in the same order. Transactional replication is best used when the replicated data changes frequently or when the size of replicated data is not small and is not necessary to support autonomous changes of the replicated data on the Publisher and on the Subscriber.
Merge replication is the most difficult replication type. It makes possible autonomous changes to replicated data on the Publisher and on the Subscriber. With Merge replication, SQL Server captures all incremental data changes in the source and in the target databases, and reconciles conflicts according to rules you configure or using a custom resolver you create. Merge replication is best used when you want to support autonomous changes of the replicated data on the Publisher and on the Subscriber.
Hoppsan! Jag trodde den var tom... :o
wscript
Veckodag field1 field2 field3
Mån 1 500 Test
Tis 1 500 Test
Mån 2 500 Test
Tis 2 500 Test
Ett problem har uppstått med den här webbplatsens säkerhetscertifikat.
VMA
3217
Wo hu cang long. The translation from Mandarin Chinese reads: "Crouching Chuck, Hidden Norris"
Apelgatan 7A
söndag
Porten till havet...
Vänligen notera att din visitkortshållare är tillgänglig i kassan med din visitkortsbeställning endast
