har följande soap fil:
<?xml version="1.0" encoding="UTF-8"?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/1999/XMLSchema" xmlns:xsi="http://www.w3.org/1999/XMLSchema-instance">
<soapenv:Body>
<ns1:getNewsTitlesFromGroupResponse soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:ns1="urn:weiii">
<getNewsTitlesFromGroupReturn xsi:type="ns2:ArrayOf_xsd_string" soapenc:arrayType="ns3:string[10]" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ns2="urn:weii" xmlns:ns3="http://www.w3.org/2001/XMLSchema" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/">
<item>Security standard approved by OASIS</item>
<item>webMethods join WSCC as Partners</item>
<item>OASIS members approve CAP standard</item>
<item>W3C updated drafts of WSDL 2.0</item>
<item>SAP, IBM integrate platforms</item>
<item>WRQ supports Visual Studio .NET</item>
<item>World`s first Web Services Certification Program starts April 22</item>
<item>BEA, IBM propose BPEL for Java</item>
<item>Examensjobb ökar IT-företagens konkurrenskraft</item>
<item>Manage eBay auctions from Excel</item>
</getNewsTitlesFromGroupReturn>
</ns1:getNewsTitlesFromGroupResponse>
</soapenv:Body>
</soapenv:Envelope>
och följande xsl fil
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<!-- Match The Root Node -->
<xsl:template match="/">
<HTML>
<HEAD>
<TITLE>WSCC News</TITLE>
</HEAD>
<BODY>
<h1 align="center">All the news</h1>
<ol>
<xsl:apply-templates/>
</ol>
</BODY>
</HTML>
</xsl:template>
<xsl:template match="getNewsTitlesFromGroupReturn">
<xsl:for-each select="item">
<xsl:value-of select="@item"/>
</xsl:for-each>
</xsl:template>
<xsl:template match="@*|*|text()|processing-instruction()" priority="-1">
<xsl:apply-templates select="@*|*|text()|processing-instruction()"/>
</xsl:template>
</xsl:stylesheet>
Jag har problem med att få ut <item>, hur kan man göra detta?
