Hejsan!
Jag ska installera ett WordPress-plugin - Akismet, mot spam. Se nedan - jag vet inte vad API key är för något. Någon som kan hjälpa mig?
TACK!
"Installing Akismet for WordPress
The Akismet WordPress plugin ships with WordPress 2.0 and later by default, but if you don't have it for some reason, you can download it from the official page (http://akismet.com/download/).
After downloading, go to your Plugins admin page, and click the Activate link in the same row as the Akismet plugin entry. After you've activated it, it will come up with a box below the main navigation saying that the Akismet plugin is not active, and you need to enter your WordPress.com API key."
