Hej.
Nu har jag försökt länge med att få varnish, apache2 och ESI att fungera ihop men utan större framgång.
Finns det någon här som har erfarenhet av varnish och ESI?
2 svar · 1 138 visningar · startad av jme
Hej.
Well, hur ser din varnish-conf ut? Hur skriver du ut esin?
Jag kör med varnish 2.1.5.
## Redirect requests to Apache, running on port 8000 on localhost
backend apache {
.host = "127.0.0.1";
.port = "9002";
## Fetch
sub vcl_fetch {
## Remove the X-Forwarded-For header if it exists.
remove req.http.X-Forwarded-For;
## insert the client IP address as X-Forwarded-For. This is the normal IP address of the user.
set req.http.X-Forwarded-For = req.http.rlnclientipaddr;
## Added security, the "w00tw00t" attacks are pretty annoying so lets block it before it reaches our webserver
if (req.url ~ "^/w00tw00t") {
error 403 "Not permitted";
esi; /* Do ESI processing */
unset beresp.http.set-cookie;
set beresp.ttl = 60s;
## Deliver the content
return(deliver);
## Deliver
sub vcl_deliver {
## We'll be hiding some headers added by Varnish. We want to make sure people are not seeing we're using Varnish.
## Since we're not caching (yet), why bother telling people we use it?
remove resp.http.X-Varnish;
remove resp.http.Via;
remove resp.http.Age;
## We'd like to hide the X-Powered-By headers. Nobody has to know we can run PHP and have version xyz of it.
remove resp.http.X-Powered-By;
Sedan testade jag först med två filer, foo.html och foo2.html:
foo:html
<esi:include src="/foo2.html" />
foo2.html:
bar
Jag testade även med
<esi:include src="http://localhost/foo2.html" />
