Jag har försökt att få igång PHP och PHP-FPM på min Ubuntu VPS, men har inte lyckats särskilt bra.
Jag får fel när jag ska kompilera PHP. Är det någon annan som har lyckats med det?
Jag försökte följa dessa instruktioner: http://github.com/dreamcat4/php-fpm/blob/master/readme.markdown
Men när jag ska kompilera PHP med:
../configure && make
så får jag följande felutskrifter:
../configure: 11986: ac_fn_c_check_func: not found
../configure: 11997: ac_fn_c_check_func: not found
../configure: 12147: 5: Bad file descriptor
../configure: 12147: :: checking for socket in -lsocket: not found
../configure: 12147: 6: Bad file descriptor
../configure: 12147: checking for socket in -lsocket... : not found
cat: confdefs.h: No such file or directory
../configure: 12147: ac_fn_c_try_link: not found
../configure: 12147: :: result: no: not found
../configure: 12147: no: not found
../configure: 12147: :: checking for __socket in -lsocket: not found
../configure: 12147: checking for __socket in -lsocket... : not found
../configure: 12154: ac_fn_c_check_func: not found
../configure: 12165: ac_fn_c_check_func: not found
../configure: 12315: 5: Bad file descriptor
../configure: 12315: :: checking for socketpair in -lsocket: not found
../configure: 12315: 6: Bad file descriptor
../configure: 12315: checking for socketpair in -lsocket... : not found
../configure: 12315: ac_fn_c_try_link: not found
../configure: 12315: :: result: no: not found
../configure: 12315: no: not found
../configure: 12315: :: checking for __socketpair in -lsocket: not found
../configure: 12315: checking for __socketpair in -lsocket... : not found
../configure: 12322: ac_fn_c_check_func: not found
../configure: 12333: ac_fn_c_check_func: not found
../configure: 12483: 5: Bad file descriptor
../configure: 12483: :: checking for htonl in -lsocket: not found
../configure: 12483: 6: Bad file descriptor
../configure: 12483: checking for htonl in -lsocket... : not found
../configure: 12483: ac_fn_c_try_link: not found
../configure: 12483: :: result: no: not found
../configure: 12483: no: not found
../configure: 12483: :: checking for __htonl in -lsocket: not found
../configure: 12483: checking for __htonl in -lsocket... : not found
../configure: 12490: ac_fn_c_check_func: not found
../configure: 12501: ac_fn_c_check_func: not found
../configure: 12651: 5: Bad file descriptor
../configure: 12651: :: checking for gethostname in -lnsl: not found
../configure: 12651: 6: Bad file descriptor
../configure: 12651: checking for gethostname in -lnsl... : not found
../configure: 12651: ac_fn_c_try_link: not found
../configure: 12651: :: result: no: not found
../configure: 12651: no: not found
../configure: 12651: :: checking for __gethostname in -lnsl: not found
../configure: 12651: checking for __gethostname in -lnsl... : not found
../configure: 12658: ac_fn_c_check_func: not found
../configure: 12669: ac_fn_c_check_func: not found
../configure: 12819: 5: Bad file descriptor
../configure: 12819: :: checking for gethostbyaddr in -lnsl: not found
../configure: 12819: 6: Bad file descriptor
../configure: 12819: checking for gethostbyaddr in -lnsl... : not found
../configure: 12819: ac_fn_c_try_link: not found
../configure: 12819: :: result: no: not found
../configure: 12819: no: not found
../configure: 12819: :: checking for __gethostbyaddr in -lnsl: not found
../configure: 12819: checking for __gethostbyaddr in -lnsl... : not found
../configure: 12826: ac_fn_c_check_func: not found
../configure: 12837: ac_fn_c_check_func: not found
../configure: 12987: 5: Bad file descriptor
../configure: 12987: :: checking for yp_get_default_domain in -lnsl: not found
../configure: 12987: 6: Bad file descriptor
../configure: 12987: checking for yp_get_default_domain in -lnsl... : not found
../configure: 12987: ac_fn_c_try_link: not found
../configure: 12987: :: result: no: not found
../configure: 12987: no: not found
../configure: 12987: :: checking for __yp_get_default_domain in -lnsl: not found
../configure: 12987: checking for __yp_get_default_domain in -lnsl... : not found
../configure: 12995: ac_fn_c_check_func: not found
../configure: 13006: ac_fn_c_check_func: not found
../configure: 13156: 5: Bad file descriptor
../configure: 13156: :: checking for dlopen in -ldl: not found
../configure: 13156: 6: Bad file descriptor
../configure: 13156: checking for dlopen in -ldl... : not found
../configure: 13156: ac_fn_c_try_link: not found
../configure: 13156: :: result: no: not found
../configure: 13156: no: not found
../configure: 13156: :: checking for __dlopen in -ldl: not found
../configure: 13156: checking for __dlopen in -ldl... : not found
../configure: 13164: 5: Bad file descriptor
../configure: 13164: :: checking for sin in -lm: not found
../configure: 13164: 6: Bad file descriptor
../configure: 13164: checking for sin in -lm... : not found
../configure: 13196: ac_fn_c_try_link: not found
../configure: 13198: 5: Bad file descriptor
../configure: 13198: :: result: no: not found
../configure: 13198: 6: Bad file descriptor
../configure: 13198: no: not found
../configure: 13214: ac_fn_c_check_func: not found
../configure: 13225: ac_fn_c_check_func: not found
../configure: 13510: 5: Bad file descriptor
../configure: 13510: :: checking for inet_aton in -lresolv: not found
../configure: 13510: 6: Bad file descriptor
../configure: 13510: checking for inet_aton in -lresolv... : not found
../configure: 13510: ac_fn_c_try_link: not found
../configure: 13510: :: result: no: not found
../configure: 13510: no: not found
../configure: 13510: :: checking for __inet_aton in -lresolv: not found
../configure: 13510: checking for __inet_aton in -lresolv... : not found
../configure: 13510: :: checking for inet_aton in -lbind: not found
../configure: 13510: checking for inet_aton in -lbind... : not found
../configure: 13510: :: checking for __inet_aton in -lbind: not found
../configure: 13510: checking for __inet_aton in -lbind... : not found
../configure: 13516: 5: Bad file descriptor
../configure: 13516: :: checking for ANSI C header files: not found
../configure: 13516: 6: Bad file descriptor
../configure: 13516: checking for ANSI C header files... : not found
../configure: 13615: ac_fn_c_try_compile: not found
../configure: 13617: 5: Bad file descriptor
../configure: 13617: :: result: no: not found
../configure: 13617: 6: Bad file descriptor
../configure: 13617: no: not found
../configure: 13665: ac_cv_header_dirent_dirent.h: not found
../configure: 13665: 5: Bad file descriptor
../configure: 13665: :: checking for dirent.h that defines DIR: not found
../configure: 13665: 6: Bad file descriptor
../configure: 13665: checking for dirent.h that defines DIR... : not found
eval: 1: Bad substitution
Någon som har nåt tips på hur jag kan lösa det?
