Problem med mysql administration genom WAMP
2 svar · 498 visningar · startad av Hampan90
Hampan90Medlem sedan feb. 2007137 inlägg
Nu har jag installerat wamp, och försöker komma in för att administrera databaserna via cmd.
Jag sätter ett root password:
C:\wamp\mysql\bin>mysql -u root mysql
Welcome to the MySQL monitor.  Commands end with ; or \g.
Your MySQL connection id is 1
Server version: 5.0.41-community-nt MySQL Community Edition (GPL)
Type 'help;' or '\h' for help. Type '\c' to clear the buffer.
mysql> UPDATE mysql.user SET Password=PASSWORD("XXXXXX") WHERE User="root";
Query OK, 1 row affected (0.11 sec)
Rows matched: 1  Changed: 1  Warnings: 0
mysql> FLUSH PRIVILEGES;
Query OK, 0 rows affected (0.00 sec)
mysql> quit
Bye
XXXXXX= mitt lösen
Men när jag försöker logga in med mitt nya lösen så får jag detta istället för att jag ska logga in:
C:\wamp\mysql\bin>mysql - loclahost -u root -p
mysql  Ver 14.12 Distrib 5.0.41, for Win32 (ia32)
Copyright (C) 2002 MySQL AB
This software comes with ABSOLUTELY NO WARRANTY. This is free software,
and you are welcome to modify and redistribute it under the GPL license
Usage: mysql [OPTIONS] [database]
  -?, --help          Display this help and exit.
  -I, --help          Synonym for -?
  --auto-rehash       Enable automatic rehashing. One doesn't need to use
                      'rehash' to get table and field completion, but startup
                      and reconnecting may take a longer time. Disable with
                      --disable-auto-rehash.
  -A, --no-auto-rehash
                      No automatic rehashing. One has to use 'rehash' to get
                      table and field completion. This gives a quicker start of
                      mysql and disables rehashing on reconnect. WARNING:
                      options deprecated; use --disable-auto-rehash instead.
  -B, --batch         Don't use history file. Disable interactive behavior.
                      (Enables --silent)
  --character-sets-dir=name
                      Directory where character sets are.
  --default-character-set=name
                      Set the default character set.
  -C, --compress      Use compression in server/client protocol.
  -#, --debug[=#]     This is a non-debug version. Catch this and exit
  -D, --database=name Database to use.
  --delimiter=name    Delimiter to be used.
  -e, --execute=name  Execute command and quit. (Disables --force and history
                      file)
  -E, --vertical      Print the output of a query (rows) vertically.
  -f, --force         Continue even if we get an sql error.
  -G, --named-commands
                      Enable named commands. Named commands mean this program's
                      internal commands; see mysql> help . When enabled, the
                      named commands can be used from any line of the query,
                      otherwise only from the first line, before an enter.
                      Disable with --disable-named-commands. This option is
                      disabled by default.
  -g, --no-named-commands
                      Named commands are disabled. Use \* form only, or use
                      named commands only in the beginning of a line ending
                      with a semicolon (;) Since version 10.9 the client now
                      starts with this option ENABLED by default! Disable with
                      '-G'. Long format commands still work from the first
                      line. WARNING: option deprecated; use
                      --disable-named-commands instead.
  -i, --ignore-spaces Ignore space after function names.
  --local-infile      Enable/disable LOAD DATA LOCAL INFILE.
  -b, --no-beep       Turn off beep on error.
  -h, --host=name     Connect to host.
  -H, --html          Produce HTML output.
  -X, --xml           Produce XML output
  --line-numbers      Write line numbers for errors.
  -L, --skip-line-numbers
                      Don't write line number for errors. WARNING: -L is
                      deprecated, use long version of this option instead.
  -n, --unbuffered    Flush buffer after each query.
  --column-names      Write column names in results.
  -N, --skip-column-names
                      Don't write column names in results. WARNING: -N is
                      deprecated, use long version of this options instead.
  -O, --set-variable=name
                      Change the value of a variable. Please note that this
                      option is deprecated; you can set variables directly with
                      --variable-name=value.
  --sigint-ignore     Ignore SIGINT (CTRL-C)
  -o, --one-database  Only update the default database. This is useful for
                      skipping updates to other database in the update log.
  -p, --password[=name]
                      Password to use when connecting to server. If password is
                      not given it's asked from the tty.
  -W, --pipe          Use named pipes to connect to server.
  -P, --port=#        Port number to use for connection.
  --prompt=name       Set the mysql prompt to this value.
  --protocol=name     The protocol of connection (tcp,socket,pipe,memory).
  -q, --quick         Don't cache result, print it row by row. This may slow
                      down the server if the output is suspended. Doesn't use
                      history file.
  -r, --raw           Write fields without conversion. Used with --batch.
  --reconnect         Reconnect if the connection is lost. Disable with
                      --disable-reconnect. This option is enabled by default.
  -s, --silent        Be more silent. Print results with a tab as separator,
                      each row on new line.
  --shared-memory-base-name=name
                      Base name of shared memory.
  -S, --socket=name   Socket file to use for connection.
  --ssl               Enable SSL for connection (automatically enabled with
                      other flags). Disable with --skip-ssl.
  --ssl-ca=name       CA file in PEM format (check OpenSSL docs, implies
                      --ssl).
  --ssl-capath=name   CA directory (check OpenSSL docs, implies --ssl).
  --ssl-cert=name     X509 cert in PEM format (implies --ssl).
  --ssl-cipher=name   SSL cipher to use (implies --ssl).
  --ssl-key=name      X509 key in PEM format (implies --ssl).
  --ssl-verify-server-cert
                      Verify server's "Common Name" in its cert against
                      hostname used when connecting. This option is disabled by
                      default.
  -t, --table         Output in table format.
  -T, --debug-info    Print some debug info at exit.
  --tee=name          Append everything into outfile. See interactive help (\h)
                      also. Does not work in batch mode. Disable with
                      --disable-tee. This option is disabled by default.
  --no-tee            Disable outfile. See interactive help (\h) also. WARNING:
                      option deprecated; use --disable-tee instead
  -u, --user=name     User for login if not current user.
  -U, --safe-updates  Only allow UPDATE and DELETE that uses keys.
  -U, --i-am-a-dummy  Synonym for option --safe-updates, -U.
  -v, --verbose       Write more. (-v -v -v gives the table output format).
  -V, --version       Output version information and exit.
  -w, --wait          Wait and retry if connection is down.
  --connect_timeout=# Number of seconds before connection timeout.
  --max_allowed_packet=#
                      Max packet length to send to, or receive from server
  --net_buffer_length=#
                      Buffer for TCP/IP and socket communication
  --select_limit=#    Automatic limit for SELECT when using --safe-updates
  --max_join_size=#   Automatic limit for rows in a join when using
                      --safe-updates
  --secure-auth       Refuse client connecting to server if it uses old
                      (pre-4.1.1) protocol
  --show-warnings     Show warnings after every statement.
Default options are read from the following files in the given order:
C:\my.ini C:\my.cnf C:\WINDOWS\my.ini C:\WINDOWS\my.cnf C:\wamp\mysql\my.ini C:\
wamp\mysql\my.cnf
The following groups are read: mysql client
The following options may be given as the first argument:
--print-defaults        Print the program argument list and exit
--no-defaults           Don't read default options from any options file
--defaults-file=#       Only read default options from the given file #
--defaults-extra-file=# Read this file after the global files are read
Variables (--variable-name=value)
and boolean options {FALSE|TRUE}  Value (after reading options)
auto-rehash                       TRUE
character-sets-dir                (No default value)
(..... massor av text)
show-warnings                     FALSE
C:\wamp\mysql\bin>
Varför blir det såhär? har haft problemet förut, var lite därför som jag inte ville köra wamp.
TulorkMedlem sedan aug. 2004903 inlägg
dum fråga kanske... provat starta om mysql?
(startar om WAMP)
Nej, ingen skillnad
257 ms totalt · 3 externa anrop · v20260731065814-full.30151723
125 ms — hämta statistik (db)
