Mystisk händelse.....
1 svar · 179 visningar · startad av Swedemister
SwedemisterMedlem sedan okt. 2003178 inlägg
Har ett omröstningscript, funkar jättebra men, då man klickar på svarsallternativen , Yes, No, I´m not sure so kommer detta:
Not Found
The requested URL /member/start.html was not found on this server.
Apache/1.3.27 Server at https://www.minsida.com Port 80
Men den skall ju gå tillbaka, finns inget i rosta.php som tyder på att den skall till member/start.html inget alls.....
rosta.php kod.
# SCRIPT
 include("./voteVariablar.php");
$ipnummer = $_SERVER['REMOTE_ADDR'];
$idg = date("Ymd");
  if(isset($vote) && $voteID) {
	//Kontrolerar så att inte besökaren försöker fuska.
	$kollaFusk = mysql_query("SELECT * FROM votes WHERE ip='$ipnummer' AND votedag='$idg'");
		$fusk=mysql_fetch_object($kollaFusk);
		if($fusk) {
		header("location: $votepoll[include]?fel");
	} else {
        $get = mysql_query("SELECT * FROM votepoll WHERE voteID='$voteID'");
		$sk = mysql_fetch_array($get);
	     		$rost_01 = $sk["rost_01"];
             		$rost_02 = $sk["rost_02"];
             		$rost_03 = $sk["rost_03"];
             		$rost_04 = $sk["rost_04"];
             		$rost_05 = $sk["rost_05"];
             		$rost_06 = $sk["rost_06"];
             		$rost_07 = $sk["rost_07"];
             		$rost_08 = $sk["rost_08"];
			$ant_rost = $sk["ant_rost"];
			$ant_rost = $ant_rost + 1;
				// Kollar vilkte alternativ som fick rösten:
				if($vote == 1) {
				$rost_01 = $rost_01 + 1;
				} else { $rost_01 = $rost_01;}
				if($vote == 2) {
				$rost_02 = $rost_02 + 1;
				} else { $rost_02 = $rost_02;}
				if($vote == 3) {
				$rost_03 = $rost_03 + 1;
				} else { $rost_03 = $rost_03;}
				if($vote == 4) {
				$rost_04 = $rost_04 + 1;
				} else { $rost_04 = $rost_04;}
				if($vote == 5) {
				$rost_05 = $rost_05 + 1;
				} else { $rost_05 = $rost_05;}
				if($vote == 6) {
				$rost_06 = $rost_06 + 1;
				} else { $rost_06 = $rost_06;}
				if($vote == 7) {
				$rost_07 = $rost_07 + 1;
				} else { $rost_07 = $rost_07;}
				if($vote == 8) {
				$rost_08 = $rost_08 + 1;
				} else { $rost_08 = $rost_08;}
				mysql_query("UPDATE votepoll SET
						     		rost_01 = '$rost_01',
             							rost_02 = '$rost_02',
             							rost_03 = '$rost_03',
             							rost_04 = '$rost_04',
             							rost_05 = '$rost_05',
             							rost_06 = '$rost_06',
             							rost_07 = '$rost_07',
             							rost_08 = '$rost_08',
								ant_rost = '$ant_rost' WHERE voteID='$voteID'");
	if($votepoll['rosta'] == "ja") {
	mysql_query("INSERT INTO votes (ip,votedag) VALUES('$ipnummer','$idg')");
		header("location: $votepoll[include]?rost");
} else {
header("location: $votepoll[include]");
Fattar ingenting, vart får den det ifrån, Gjorde en html sida som heter start.html och sen en reload till rosta.php men den hittar inte den heller.......
AsterixMedlem sedan dec. 1999483 inlägg
Antagligen innehåller $votepoll[include], som antagligen kommer från voteVariablar.php, start.html.
131 ms totalt · 3 externa anrop · v20260731065814-full.7de19299
