Har ett omröstningscript, funkar jättebra men, då man klickar på svarsallternativen , Yes, No, I´m not sure so kommer detta:
Not Found
The requested URL /member/start.html was not found on this server.
Apache/1.3.27 Server at https://www.minsida.com Port 80
Men den skall ju gå tillbaka, finns inget i rosta.php som tyder på att den skall till member/start.html inget alls.....
rosta.php kod.
# SCRIPT
include("./voteVariablar.php");
$ipnummer = $_SERVER['REMOTE_ADDR'];
$idg = date("Ymd");
if(isset($vote) && $voteID) {
//Kontrolerar så att inte besökaren försöker fuska.
$kollaFusk = mysql_query("SELECT * FROM votes WHERE ip='$ipnummer' AND votedag='$idg'");
$fusk=mysql_fetch_object($kollaFusk);
if($fusk) {
header("location: $votepoll[include]?fel");
} else {
$get = mysql_query("SELECT * FROM votepoll WHERE voteID='$voteID'");
$sk = mysql_fetch_array($get);
$rost_01 = $sk["rost_01"];
$rost_02 = $sk["rost_02"];
$rost_03 = $sk["rost_03"];
$rost_04 = $sk["rost_04"];
$rost_05 = $sk["rost_05"];
$rost_06 = $sk["rost_06"];
$rost_07 = $sk["rost_07"];
$rost_08 = $sk["rost_08"];
$ant_rost = $sk["ant_rost"];
$ant_rost = $ant_rost + 1;
// Kollar vilkte alternativ som fick rösten:
if($vote == 1) {
$rost_01 = $rost_01 + 1;
} else { $rost_01 = $rost_01;}
if($vote == 2) {
$rost_02 = $rost_02 + 1;
} else { $rost_02 = $rost_02;}
if($vote == 3) {
$rost_03 = $rost_03 + 1;
} else { $rost_03 = $rost_03;}
if($vote == 4) {
$rost_04 = $rost_04 + 1;
} else { $rost_04 = $rost_04;}
if($vote == 5) {
$rost_05 = $rost_05 + 1;
} else { $rost_05 = $rost_05;}
if($vote == 6) {
$rost_06 = $rost_06 + 1;
} else { $rost_06 = $rost_06;}
if($vote == 7) {
$rost_07 = $rost_07 + 1;
} else { $rost_07 = $rost_07;}
if($vote == 8) {
$rost_08 = $rost_08 + 1;
} else { $rost_08 = $rost_08;}
mysql_query("UPDATE votepoll SET
rost_01 = '$rost_01',
rost_02 = '$rost_02',
rost_03 = '$rost_03',
rost_04 = '$rost_04',
rost_05 = '$rost_05',
rost_06 = '$rost_06',
rost_07 = '$rost_07',
rost_08 = '$rost_08',
ant_rost = '$ant_rost' WHERE voteID='$voteID'");
if($votepoll['rosta'] == "ja") {
mysql_query("INSERT INTO votes (ip,votedag) VALUES('$ipnummer','$idg')");
header("location: $votepoll[include]?rost");
} else {
header("location: $votepoll[include]");
Fattar ingenting, vart får den det ifrån, Gjorde en html sida som heter start.html och sen en reload till rosta.php men den hittar inte den heller.......
