Det krånglar med min player klass..
problemet uppstår när man kör parent::Insert()
Varför?
// Index.php
include("mysql.php");
include("player_class.php");
$player = new Player;
$player->Add_player("$table","$player","$fodelse_id");
// Start of class player...
class Player extends MySQL {
function Add_player($table,$player,$fodelse_datum) {
// Check to see if all inputs are correct
if($table == "" || $player == "" || $fodelse_datum == "")
echo "One or more arguments for function is missing.<br>";return false; exit;
// Connect..
parent::MySQL();
// Set database
parent::Set_database("database","");
// Insert value
parent::Insert("$table","'','$name','$fodelse_datum'");
} // <-- End of class Player
// Start MySQL Class -->
class MySQL{
var $host = "localhost";
var $username = "root";
var $password = "";
var $database = "";
var $dblink;
var $error;
// Konstruktor
function MySQL(){
// Set values of each parameter
$host = $this->host;
$username = $this->username;
$password = $this->password;
$database = $this->database;
$error = $this->error;
// Connect to MySQL If there were errors, give error msgs and exit
if(!$this->dblink = mysql_connect($host,$username,$password)){
echo mysql_error(); return false; exit;}
// Retrun true if all is successfull
return true;}
// Function for inserting values into a table and cells
function Insert($table,$values){ // tablename,cols,values
// Check so that no arguments were empty
if($table == "" || $values == ""){
echo "One or more argument(s) was empty for function '<b>Insert</b>' in the class '<b>MySQL</b>'"; return false; exit;}
// Do insert request, check for failure
if(!mysql_query("INSERT INTO $table VALUES($values)")){
// Return true if all is successfull
return true;}
function Update($table,$cols,$values,$where){ // tablename,columns,values,where
if($table == "" || $cols == "" || $values == "" || $where == ""){
echo "One or more argument(s) was empty for function '<b>Update</b>' in the class '<b>MySQL</b>'"; return false; exit;}
// Split values
$values = explode(",",$values);
// Split cells
$cols = explode(",",$cols);
// Check so that $values and $cells have the same amount of values
if(count($values) != count($cols)){
echo "Array $colls ans array $values did not have the same amount of values in function '<b>Update</b>' in the class '<b>MySQL</b>'"; return false; exit;}
// Get the correct SET MySQL syntax
for($i=0;$i < count($values);$i++){
$set .= $cols[$i] . "='" .$values[$i] . "'";
if($i < count($values)-1){
$set .= ",";}}
// Do update request
if(!mysql_query("UPDATE $table SET $set WHERE $where")){
// Retrun true if all is succsessfull
return true;}
function Delete($table,$where){ // tablename,where
if($table == "" || $where == ""){
echo "One or more argument(s) was empty for function '<b>Delete</b>' in the class '<b>MySQL</b>'"; return false; exit;}
// Do Delete request
if(!mysql_query("DELETE FROM $table WHERE $where")){
return true;}
function Select($table,$cols,$where="",$limit="",$orderby=""){ // table,columns,where,limit,orderby returns an array.
// Check so that no required arguments were empty
if($table == "" || $cols == ""){
echo "One or more argument(s) was empty for function '<b>Select</b>' in the class '<b>MySQL</b>'"; return false; exit;}
// Check for WHERE statement
if($where != ""){
$set .= " WHERE $where";}
// Check for ORDER BY statement
if($orderby != ""){
$set .= " ORDER BY $orderby";}
// Check for LIMIT statement
if($limit != ""){
$set .= " LIMIT $limit";}
// Do Select request
$query = mysql_query("SELECT $cols FROM $table$set");
while($sql_result = mysql_fetch_array($query,MYSQL_NUM)){ $array[] = $sql_result;}
// Return asociative array
return $array;}
function Showtables($show_thread) {
// Get values
$link = $this->dblink;
// Create result list
if (!$error)
$result = mysql_list_tables($database);
else {
return false;
exit;
// If not result.. explain why
if (!$result) {
print "Listing tables error " . "<br>";
print 'MySQL Says: ' . mysql_error();
exit;
// print the talbles
while ($row = mysql_fetch_row($result)) {
print "Table: $row[0]\n" . "<br>";
if (isset($show_thread)) {
$fields = mysql_list_fields($database, $row[0], $link);
$columns = mysql_num_fields($fields);
echo "<ul>";
for ($i = 0; $i < $columns; $i++) {
echo "<li>" . mysql_field_name($fields, $i) . " [" . $this->fieldinfo(mysql_field_name($fields, $i),$row[0]) . "] " . "<br></li>";
echo "</ul>";
// Free result
mysql_free_result($result);
} // <-- End of function
function Set_database($db,$show_succes="yes") {
// Check so required argument are not empty
if($db==""){
echo "One or more argument(s) was empty for function '<b>Set_database</b>' in the class '<b>MySQL</b>'"; return false; exit;}
$dblink = $this->dblink;
// Create a list with databases
$db_list = mysql_list_dbs($dblink);
// Chech to see if database exists
$i = 0;
$count = mysql_num_rows($db_list);
while ($i < $count && $flag==0) {
if (mysql_db_name($db_list, $i) == $db)
$flag=1;
$flag=0;
$i++;
// If flag=0 then database do not exist
if ($flag==0){
echo "The database you wanted to use don't exist";
$this->error = true;
return false;
exit;
// If succesfull
if($flag==1 && $show_succes=="yes")
$this->database = $db;
mysql_select_db($db) or die(mysql_error());
echo "Using Database <b>[". $db . "]</b>";
return true;} // <-- End of function
function fieldinfo($field,$table) {
// Check if field is not empty
if($field=="" && $table=="") {
echo "One or more arguments in function '<b>fieldinfo()</b>' is empty"; return false; exit; }
$result = mysql_query("select $field from $table");
$i = 0;
while ($i < mysql_num_fields($result)) {
$meta = mysql_fetch_field($result);
if (!$meta) {
echo "No info";
// Echo out the parameters...
if($meta->type)
$str = $meta->type;
if($meta->primary_key)
$str = $str . ", primary key";
$i++;
return $str;
// <-- End Class
