Hej hej :)
Jag undrar hur man får fram den nya postens nummer efter det att man har insert:at en ny post?
Jag använder MySql
/Grodan
4 svar · 264 visningar · startad av GrodanBoll
Hej hej :)
Jag använder MySql
/Grodan
int mysql_insert_id ( [resource link_identifier])
mysql_insert_id() returns the ID generated for an AUTO_INCREMENT column by the previous INSERT query using the given link_identifier. If link_identifier isn't specified, the last opened link is assumed.
mysql_insert_id() returns 0 if the previous query does not generate an AUTO_INCREMENT value. If you need to save the value for later, be sure to call mysql_insert_id() immediately after the query that generates the value.
Fel forum btw ;)
Denna går också o använda
Also note that the value of the SQL LAST_INSERT_ID() function always contains the most recently generated AUTO_INCREMENT value, and is not reset between queries because the value of that function is maintained in the server.
RTFM? ;)
Tackar :bire
ett annat script...
jag använder mig av detta när jag vill veta id:t från senaste posten...
$open = mysql_connect ("localhost", "$dbu","$dbp");
$sql = "SELECT id FROM tabell order by id desc limit 1";
$result = mysql_db_query("databasnamn","$sql");
while($row=mysql_fetch_array($result)){
$senaste_id = $row['id'];
