Problem med loop, ingen data skrivs ut
2 svar · 185 visningar · startad av Del Pero
Del PeroMedlem sedan feb. 20003 785 inlägg
Jag behöver hjälp med att hitta felet i denna koden. Ingen data skrivs ut trots att tabellen inte är tom.
$link = mysql_connect($db_host, $db_user, $db_pass);
	mysql_select_db($db, $link);
	$sql = "SELECT * FROM `tblgalleryphotos`";
	$result = mysql_query($sql, $link);
	while ($array = mysql_fetch_array($result)) {
		"<tr>\n";
		"<td class=\"text\"><a href=\"".$_SERVER['PHP_SELF']."?page=content/edit_photo&id=".$array['photoID']."\" title=\"".$array['photoDesc']."\">".$array['photoFilename']."</a></td>\n";
		"<td class=\"text\"><a href=\"".$_SERVER['PHP_SELF']."?action=delete_photo&id=".$array['photoID']."\">Ta bort</a></td>\n";
		"</tr>\n";
mvh,
stresspero
stevenetMedlem sedan juni 20001 251 inlägg
Du har glömt echo vid varje rad(?)
[b]echo[/b] "<tr>\n";
[b]echo[/b] "<td class=\"text\"><a href=\"".$_SERVER['PHP_SELF']."?page=content/edit_photo&id=".$array['photoID']."\" title=\"".$array['photoDesc']."\">".$array['photoFilename']."</a></td>\n";
[b]echo[/b] "<td class=\"text\"><a href=\"".$_SERVER['PHP_SELF']."?action=delete_photo&id=".$array['photoID']."\">Ta bort</a></td>\n";
[b]echo[/b] "</tr>\n";
Japp, det hade jag. Tackar. :)
147 ms totalt · 3 externa anrop · v20260731065814-full.0e50b1ef
