Installera PHP
2 svar · 191 visningar · startad av Smultron
SmultronMedlem sedan juli 2002431 inlägg
Hur installerar man PHP på en Orionserver?
mikkeXMedlem sedan aug. 2002490 inlägg
Från http://www.orionsupport.com/articles/php.html:
Getting PHP to run in Orion is trivial: simply make sure that the process running Orion has PHP in the executable path. If you're building PHP manually, don't bother with the --with-java and --with-servlet configuration options. If PHP is in the executable path, Orion's built-in PHP mapping will kick in for all files ending with .php.
mm men vilken är executable path?
Genererad på 366 ms · cache AV · v20260730165559-full.f96bc7eb
