Matte skrev:
Nu vet jag inte hur din kod ser ut, men en absolutsökväg utgår vanligtvis från diskroten (möjligtvis från webroten).
Sedan behöver du en katalog att ladda upp dina filer i. Denna katalog måste ha skrivrättigheter.
Du kan t.ex skapa katalogen upload under lindstrom.
Då skulle det kunna se ut så här:
$absolute_path = $_SERVER['DOCUMENT_ROOT']."/lindstrom/upload/"; //Absolute path to where files are uploaded
Får då upp:
Notice: Undefined index: DOCUMENT_ROOT in C:\UserLib\lindstrom\config.php on line 7
Jag bifogar hela koden:
//Advanced Uploader V1.00b
//Copyright 2002 ZachWhite.com
//By using this program you agree with the license provide with it.
//Script by Zach White http://www.zachwhite.com zachwhite@zachwhite.com
if(!isset($upload)) {
$upload = "";
switch($upload) {
default:
include "config.php";
echo "
<html>
<title>Upload</title>
<body topmargin=\"10\" leftmargin=\"0\" bgcolor=\"#18576F\" link=\"#818EA0\" vlink=\"#5C697A\" alink=\"#818EA0\" text=\"#FFFFFF\" style=\"font-family: Verdana; font-size: 8pt; color: #FFFFFF\">
<div align=\"center\">
<center>
<table border=\"0\" cellpadding=\"0\" cellspacing=\"0\" style=\"border-collapse: collapse\" bordercolor=\"#111111\" width=\"400\" id=\"AutoNumber1\">
<tr>
<td bgcolor=\"#5E6A7B\" height=\"25\">
<p align=\"center\"><font size=\"2\"><b>Upload File</b></font></td>
</tr>
<tr>
<td bgcolor=\"#818EA0\"><font size=\"2\">The following restrictions apply:</font><ul type=\"square\">
<li><font size=\"2\">File extension must be <b>";
if (($extensions == "") or ($extensions == " ") or ($ext_count == "0") or ($ext_count == "") or ($limit_ext != "yes") or ($limit_ext == "")) {
echo "any extension";
} else {
$ext_count2 = $ext_count+1;
for($counter=0; $counter<$ext_count; $counter++) {
echo " $extensions[$counter]";
if (($limit_size == "") or ($size_limit != "yes")) {
$limit_size = "any size";
} else {
$limit_size .= " bytes";
echo"</b></font></li>
<li><font size=\"2\">Maximum file size is $limit_size</font></li>
<li><font size=\"2\">No spaces in the filename</font></li>
<li><font size=\"2\">Filename cannot contain illegal characters
(/,*,\,etc)</font><BR>
</li>
</ul>
<form method=\"POST\" action=\"index.php?upload=doupload\" enctype=\"multipart/form-data\">
<input type=file name=file size=30 style=\"font-family: v; font-size: 10pt; color: #5E6A7B; border: 1px solid #5E6A7B; padding-left: 4; padding-right: 4; padding-top: 1; padding-bottom: 1\"><br>
<br>
<button name=\"submit\" type=\"submit\" style=\"font-family: v; font-size: 10pt; color: #5E6A7B; border: 1px solid #5E6A7B; padding-left: 4; padding-right: 4; padding-top: 1; padding-bottom: 1\">Upload</button>
</p>
<p>
</td>
</tr>
<tr>
<p align=\"center\"><font size=\"1\">
<a href=\"http://www.zachwhite.com/index.php\\"><font color=\"#FFFFFF\">
ZachWhite.com File Uploader</font></a></font><br>
<font size=\"1\">Template By <a href=\"http://www.peekj.ca\">
<font color=\"#FFFFFF\">Jan Ole Peek</font></a></font></td>
</tr>
</table>
</center>
</html>";
break;
case "doupload":
$endresult = "<font size=\"2\">File Was Uploaded</font>";
if ($file_name == "") {
$endresult = "<font size=\"2\">No file selected</font>";
}else{
if(file_exists("$absolute_path/$file_name")) {
$endresult = "<font size=\"2\">File Already Existed</font>";
} else {
if (($size_limit == "yes") && ($limit_size < $file_size)) {
$endresult = "<font size=\"2\">File was to big</font>";
} else {
$ext = strrchr($file_name,'.');
if (($limit_ext == "yes") && (!in_array($ext,$extensions))) {
$endresult = "<font size=\"2\">File is wrong type</font>";
}else{
@copy($file, "$absolute_path/$file_name") or $endresult = "<font size=\"2\">Couldn't Copy File To Server</font>";
echo "
<html>
<center>
<tr>
</tr>
<tr>
<center> $endresult </center>
</td>
</tr>
<tr>
</tr>
</table>
</center>
</html>";
break;
