Hela sidan, om nån ids kolla:
<?php
// required variables
require("config.php");
<html>
<title>Product list</title>
<style>
A:Link {color:000000;text-decoration:none;}
A:Visited {color:000000;text-decoration:none;}
A:Hover {color:F70404;text-decoration:underline;}
</style>
</HEAD>
<BODY TEXT="#000000" BGCOLOR="#FFFFFF" LINK="#000000" VLINK="#000000" ALINK="#F70404">
<center>
<?php
// database connection
mysql_connect("$host","$user","$pass");
// database selection
mysql_select_db("$database");
// query to get the products of type $category
$result = mysql_query("select * from products where(art_no = '$art_no') ORDER BY 'item'");
echo "<FORM NAME=\"itemsform\">
<HR WIDTH=75% size=1 COLOR=\"#000000\">
</font><TABLE BORDER=0 CELLSPACING=5 CELLPADDING=5>";
// define the product array
$prod = Array();
// option prices array
$optprices = Array();
// array counter
$i = 0;
while($row = mysql_fetch_row($result)) {
$prod[$i] = $row[0];
echo "<TR ALIGN=Left VALIGN=Bottom>
<TD><IMG SRC=\"images/$row[6]\" BORDER=\"0\"></TD>
<TD WIDTH=\"300\"><font size=\"2\" face=\"Verdana, Arial, Helvetica, sans-serif\"><B>$row[3]</B></FONT><BR>
<font size=\"1\" face=\"Verdana, Arial, Helvetica, sans-serif\"><B>$txt_art_no</B> $row[2]</FONT><P>
$row[4]<P>
<B>$txt_price</B> $row[5]<P>
<B>$txt_order</B></FONT><BR>
<INPUT TYPE=\"value\" NAME=\"id$row[2]quant\" VALUE=\"1\" SIZE=3>";
if( $row[7] >"0") {
echo ("<SELECT name=\"id$row[2]option\"><OPTION>$row[7]</OPTION>") ;
} else {
echo ("<SELECT name=\"id$row[2]option\"><OPTION>-</OPTION>") ;
if( $row[8] >"0") {
echo ("<OPTION>$row[8]</OPTION>") ;
if( $row[9] >"0") {
echo ("<OPTION>$row[9]</OPTION>") ;
if( $row[10] >"0") {
echo ("<OPTION>$row[10]</OPTION>") ;
if( $row[11] >"0") {
echo ("<OPTION>$row[11]</OPTION>") ;
if( $row[12] >"0") {
echo ("<OPTION>$row[12]</OPTION>") ;
if( $row[13] >"0") {
echo ("<OPTION>$row[13]</OPTION>") ;
if( $row[14] >"0") {
echo ("<OPTION>$row[14]</OPTION>") ;
if( $row[15] >"0") {
echo ("<OPTION>$row[15]</OPTION>") ;
if( $row[16] >"0") {
echo ("<OPTION>$row[16]</OPTION>") ;
echo "</SELECT><INPUT NAME=\"id$row[2]number\" TYPE=Hidden VALUE=\"$row[2]\">
<INPUT TYPE=\"button\" NAME=\"id$row[2]add\" VALUE=\"$txt_add\" style=\"font-family: Verdana, Geneva, Helvetica; font-weight: regular; font-style: regular; font-size: 10px; color: #000000; height:20px\" onclick=\"top.cart.buyItem('$row[3]','$row[5]', document.itemsform.id$row[2]quant.value, document.itemsform.id$row[2]number.value, document.itemsform.id$row[2]option.options[document.itemsform.id$row[2]option.selectedIndex].text)\"></TD></TR>";
echo "<TR><TD><font size=\"-2\" face=\"Verdana, Arial, Helvetica, sans-serif\">
<A HREF=\"javascript:history.go(-1)\">< $txt_backwards</A></font>
</TD></TR></table><HR WIDTH=75% size=1 COLOR=\"#000000\">
<font size=\"-2\" face=\"Verdana, Arial, Helvetica, sans-serif\"><b>| <a href=\"basket.php\" target='basket'>$txt_shopping_cart</a> |
<a href=\"order.php\">$txt_send_order</a> |</b>
<P>$txt_copyright</font>";
</center>
</html>
