<?php
// Connect here..
if ($action == "delete") {
mysql_query("DELETE FROM sb WHERE id = $id ");
echo "<?xml version=\"1.0\" encoding=\"ISO-8859-1\"?>";
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="sv" lang="sv">
<title>Robert</title>
<body>
<?php
$result = mysql_query("SELECT * FROM sb2 ORDER BY id DESC");
while($row = mysql_fetch_array($result)){
<b>ID:</b> <?=$row['id']?><br />
<b>Inlägg:</b> <?=$row['inlagg']?><br /><br />
<br /><br />
<form action="<?=$PHP_SELF;?>">
ID: <input type="text" name="id" /> <input type="submit" value="Delete" />
<input type="hidden" name="action" value="delete" />
</html>
eller..
<?php
// Connect here..
<body>
<?php
<input type="submit" value="Delete this" />
<input type="hidden" name="id" value="<?=$row['id']?>" />
</html>
