Hmm. SKickar med hela .php sidan så ser du hur det ser ut:
<?php
session_start();
if ($HTTP_SESSION_VARS["sessionsid"]!="OK")
header("Location: http://XXX/inloggning.php");
exit();
<html>
<title>Admin user</title>
<link rel="stylesheet" type="text/css" href="bakgrund.css">
<body>
<?php
if (isset($Uppdatera)){
$dbconn=mysql_connect("localhost","XXX","XXX") or die(mysql_error());
mysql_select_db("sys19",$dbconn) or die(mysql_error());
$sql="SELECT * FROM authuser WHERE username='$updateknapp'";
$resultat=mysql_query($sql);
$kolumn=mysql_fetch_array($resultat);
$fornamn=$kolumn["forename"];
$efternamn=$kolumn["lastname"];
$anvandarnamn=$kolumn["username"];
//$decrypttext=mcrypt_decrypt(MCRYPT_TripleDES,$key,$kolumn["password"],MCRYPT_MODE_CBC,$iv);
//$losenord=$decrypttext;
$losenord=$kolumn["password"];
$startdatum=$kolumn["startdate"];
$stopdatum=$kolumn["enddate"];
mysql_close($dbconn) or die(mysql_error());
$uppdateraok="OK";
if (isset($ny)){
$fornamn = "";
$efternamn = "";
$anvandarnamn = "";
$losenord = "";
$startdatum = "";
$stopdatum = "";
$uppdateraok="NO";
if(isset($spara)){
//$iv=mcrypt_create_iv(mcrypt_get_iv_size(MCRYPT_TripleDES,MCRYPT_MODE_CBC),MCRYPT_RAND);
//$crypttext=mcrypt_encrypt(MCRYPT_TripleDES,$key,$losenord,MCRYPT_MODE_CBC,$iv);
$dbconn=mysql_connect("localhost","sys19","5Bastards") or die(mysql_error());
if($uppdateraok=="OK"){
$sql="UPDATE authuser SET username='$anvandarnamn',password='$losenord',forename='$fornamn',lastname='$efternamn',startdate='$startdatum',enddate='$stopdatum' WHERE username='$anvandarnamn'";
$uppdateraok=="NO";
}else{
$sql="INSERT INTO authuser (username,password,forename,lastname,startdate,enddate) VALUES ('$anvandarnamn','$losenord','$fornamn','$efternamn','$startdatum','$stopdatum')";
echo("\<form action=\\"$PHP_SELF\\" method=\\"post\\"\>\\n");
echo("Förnamn:\</br\>\\n");
echo("\<input type=\\"text\\" name=\\"fornamn\\" size=\\"30\\" value=\\"$fornamn\\"\>\</br\>\\n");
echo("Efternamn:\</br\>\\n");
echo("\<input type=\\"text\\" name=\\"efternamn\\" size=\\"30\\" value=\\"$efternamn\\"\>\</br\>\\n");
echo("Användarnamn:\</br\>\\n");
echo("\<input type=\\"text\\" name=\\"anvandarnamn\\" size=\\"30\\" value=\\"$anvandarnamn\\"\>\</br\>\\n");
echo("Lösenord:\</br\>\\n");
echo("\<input type=\\"text\\" name=\\"losenord\\" size=\\"30\\" value=\\"$losenord\\"\>\</br\>\\n");
echo("Startdatum:\</br\>\\n");
echo("\<input type=\\"text\\" name=\\"startdatum\\" size=\\"30\\" value=\\"$startdatum\\"\>\</br\>\\n");
echo("Stoppdatum:\</br\>\\n");
echo("\<input type=\\"text\\" name=\\"stopdatum\\" size=\\"30\\" value=\\"$stopdatum\\"\>\</br\>\\n");
echo("\<input type=\\"submit\\" name=\\"spara\\" value=\\"Spara\\"\>\\n");
echo("\<input type=\\"reset\\" name=\\"rensa\\" value=\\"Rensa\\" onreset=\\"reset\\"\>\\n");
echo("\<input type=\\"submit\\" name=\\"ny\\" value=\\"Ny\\"\>\\n");
echo("\</form\>");
$sql="SELECT \* FROM authuser;";
$recordset=mysql_query($sql,$dbconn) or die(mysql_error());
while($record=mysql_fetch_array($recordset))
echo("Användarnamn: ".$record\["username"\]."\</br\>\\n");
echo("Lösenord: ".$record\["password"\]."\</br\>\\n");
echo("Förnamn: ".$record\["forename"\]."\</br\>\\n");
echo("Efternamn: ".$record\["lastname"\]."\</br\>\\n");
echo("Startdatum: ".$record\["startdate"\]."\</br\>\\n");
echo("Stopdatum: ".$record\["enddate"\]."\</br\>\\n");
echo("\<form action=\\"http:/XXX/deladmin.php\\" method=\\"post\\"\>\\n");
echo("\<input type=\\"hidden\\" name=\\"tabortknapp\\" value=\\"{$record\["username"\]}\\"\>\\n");
echo("\<input type=\\"submit\\" value=\\"Ta Bort\\"\>\\n");
echo("\</form\>");
echo("\<input type=\\"hidden\\" name=\\"updateknapp\\" value=\\"{$record\["username"\]}\\"\>\\n");
echo("\<input type=\\"submit\\" name=\\"Uppdatera\\" value=\\"Uppdatera\\"\>\\n");
echo("\</form\>");
echo("\<p\>-------------------------------------------------------------\</p\>\</br\>");
</html>
