Hittar inte felet
11 svar · 274 visningar · startad av Jon
JonMedlem sedan juli 20011 126 inlägg
Mailet skickas aldrig. Varför? :)
phpkod:
if($Submit)
  mail("x@x.se", "Kundkontakt från webbsidan",
Namn: $txtNamn
Företag: $txtForetag
Adress: $txtAdress
Postadress: $txtPadress
Telefon: $txtTel
Fax: $txtFax
E-post:  $txtEpost
Antal anställda: $txtAnst
Intresseområde: $intresse
Meddelande:  $txtMeddelande
  "From: Hemsidan");
	$mess = "<font color='red'>Ditt meddelande är nu skickat.</font>";
formuläret:
<form name="f" method="post" action="kontakt.php">
  <table width="78%" border="0" cellspacing="1" cellpadding="0">
    <tr>
      <td width="28%">Namn:</td>
      <td width="72%">
        <input type="text" name="txtNamn" maxlength="40" size="40">
      </td>
    </tr>
    <tr>
      <td width="28%">Företag:</td>
      <td width="72%">
        <input type="text" name="txtForetag" size="40" maxlength="40">
      </td>
    </tr>
    <tr>
      <td width="28%">Adress:</td>
      <td width="72%">
        <input type="text" name="txtAdress" size="40" maxlength="40">
      </td>
    </tr>
    <tr>
      <td width="28%">Postadress:</td>
      <td width="72%">
        <input type="text" name="txtPadress" size="40" maxlength="40">
      </td>
    </tr>
    <tr>
      <td width="28%">Telefon:</td>
      <td width="72%">
        <input type="text" name="txtTel" size="40" maxlength="40">
      </td>
    </tr>
    <tr>
    <tr>
      <td width="28%">Fax:</td>
      <td width="72%">
        <input type="text" name="txtFax" size="40" maxlength="40">
      </td>
    </tr>
    <tr>
      <td width="28%">E-post:</td>
      <td width="72%">
        <input type="text" name="txtEpost" size="40" maxlength="40">
      </td>
    </tr>
    <tr>
      <td width="28%" valign="top">Antal anst&auml;llda:</td>
      <td width="72%">
        <input type="text" name="txtAnst" size="5" maxlength="5">
      </td>
    </tr>
    <tr>
      <td width="28%">Intresseomr&aring;de: </td>
      <td width="72%">
        <select name="intresse">
          <option selected value="allt">Allt</option>
          <option value="2">2</option>
          <option value="3">3</option>
          <option value="4">4</option>
        </select>
      </td>
    </tr>
    <tr valign="top">
      <td width="28%">Meddelande:</td>
      <td width="72%">
        <textarea name="txtMeddelande" rows="6" cols="40"></textarea>
      </td>
    </tr>
    <tr valign="top">
      <td width="28%"></td>
      <td width="72%">
        <input type="Submit" name="Submit" value="Skicka">
      </td>
    </tr>
  </table>
WebslaveMedlem sedan maj 2002662 inlägg
Skummade igenom lite och fick denna tanke... testa:
if(isset($Submit)){
// Din kod
Det hjälpte tyvärr inte.
Formuläret beter sig som om det vore en reset-knapp man tryckte på. Mycket underligt...
Rensas formuläret när du trycker på submit? Skickas du inte till kontakt.php?
Japp det rensas.
Men sidan heter kontakt.php (skickar till mig själv, all kod är på samma sida)
Har du egen server? I så fall hur är inställningarna i PHP.ini? Om du har register_globals = OFF måste du kan lägga till $_POST['Submit'] osv på alla dina variablar.
Nope. webbhotell. (Loopia)
Andra mailscript har funkat bra tidigare.
Då har jag ingen aning... inte så bra på mail() ;)
OK. felsökte lite mer och upptäckte att inga variebler fått något värde! Finns det nån vanlig orsak till detta eller kan det bero på webbhotellet?
jarvkloMedlem sedan juli 20013 295 inlägg
Det är nog risk för att det låter som det skulle kunna vara en "vanlig orsak"... för (som även webslave påpekade) det låter som om du har register_globals = off på webbhotellet... (vilket IMHO är en vettig inställning för övrigt ;) )
phpmanualen skrev:
Standardvärdet för PHP-direktiven register_globals ändrades från on till off i PHP 4.2.0.
(källa: http://www.php.net/manual/sv/printwn/configuration.php )
Det innebär i praktiken bland annat att du inte längre automatiskt får tillgång till globala variabler som innehåller formulärdata som t.ex. $txtNamn i ditt exempel, utan får skriva $_POST['txtNamn'] i stället..
Om register_globals är på eller av kan du se med phpinfo();
Visst var det så!
tack för kompetent hjälp :)
Då var det ju en baggis ;) Bra att jarvklo kunde vara lite tydligare
Genererad på 395 ms · cache AV · v20260730165559-full.f96bc7eb
