Den vill inte svälja den här koden... säjer så här
Warning: Unable to create '..\PhotoArchive\A2-0.jpg': Permission denied in /home/leon/public_html/substitute/admin/adminphoto.php on line 56
Warning: Cannot add header information - headers already sent by (output started at /home/leon/public_html/substitute/admin/adminphoto.php:56) in /home/leon/public_html/substitute/admin/adminphoto.php on line 72
jag har satt CHMOD till 777 på katalogen jag föröker köra upp till,
sen får jag ju det här med headers already sent.. det fattar jag inte riktigt vad det innebär?! skulle nån kunna förklara.
:birp
<?php require_once('../Connections/subconn.php'); ?>
<?php
function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
$theValue = (!get_magic_quotes_gpc()) ? addslashes($theValue) : $theValue;
switch ($theType) {
case "text":
$theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
break;
case "long":
case "int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
$theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
break;
return $theValue;
$editFormAction = $HTTP_SERVER_VARS['PHP_SELF'];
if (isset($HTTP_SERVER_VARS['QUERY_STRING'])) {
$editFormAction .= "?" . $HTTP_SERVER_VARS['QUERY_STRING'];
if ((isset($HTTP_POST_VARS["MM_insert"])) && ($HTTP_POST_VARS["MM_insert"] == "InsertPhoto")) {
switch ($_FILES['file']['type']){
case "image/gif":
$fileext = ".gif";
break;
case $_FILES['file']['type']="image/jpeg" ||$_FILES['file']['type']="image/pjpeg":
$fileext = ".jpg";
break;
case $_FILES['file']['type']="image/png" ||$_FILES['file']['type']="image/x-png":
$fileext = ".jpg";
break;
$i = 0;
$destinationfolder = "..\\PhotoArchive\\";
$destinationfile = "$SectionID-$i$fileext";
while (file_exists($destinationfolder.$destinationfile))
$i++;
copy($file, $destinationfolder.$destinationfile);
$insertSQL = sprintf("INSERT INTO sphoto (SectionID, Name, Comments, Url) VALUES (%s, %s, %s, %s)",
GetSQLValueString($HTTP_POST_VARS['SectionID'], "int"),
GetSQLValueString($HTTP_POST_VARS['Name'], "text"),
GetSQLValueString($HTTP_POST_VARS['Comments'], "text"),
GetSQLValueString($destinationfile, "text"));
mysql_select_db($database_subconn, $subconn);
$Result1 = mysql_query($insertSQL, $subconn) or die(mysql_error());
$insertGoTo = "adminmenu.php";
$insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
$insertGoTo .= $HTTP_SERVER_VARS['QUERY_STRING'];
header(sprintf("Location: %s", $insertGoTo));
