Felmeddelande
PHP
1 svar · 182 visningar · startad av streetrobban
Medlem sedan jan. 20011 140 inlägg
Jag håller på med en sida då man kan tippa resultat på diverse matcher, men scriptet som ska ge medlemmarna poäng när man godkänner en match buggar lite, koder är den här:
	<?php
	require '../inc/db.php';
	// Choose the right table
	$get = mysql_query("SELECT * FROM Tips WHERE Tips_GameID = '$Games_ID'");
	$Scoren = "$Games_Score1-$Games_Score2";
	$Tippen = "$userRow['Tips_Result1']-$userRow['Tips_Result2']";
	// Count the posts
	$rowCount = mysql_numrows($get);
	// If there are no
	if ($rowCount == 0)
		echo "None tipped this game.";
		while($userRow = mysql_fetch_array($get))
			if ("$Scoren" == "2-0")
				if ("$Tippen" == "2-0")
				$update = "UPDATE Users SET Users_Points + 8 WHERE Users_UserName = '$userRow["Tips_UserName"]'";
				$update2 = mysql_query($update) or die (mysql_error());
				if ("$Tippen" == "2-1")
				$update = "UPDATE Users SET Users_Points + 4 WHERE Users_UserName = '$userRow["Tips_UserName"]'";
			if ("$Scoren" == "0-2")
				if ("$Tippen" == "0-2")
				if ("$Tippen" == "1-2")
			if ("$Scoren" == "2-1")
			if ("$Scoren" == "1-2")
		// Close database
		mysql_close();
och felmeddelandet:
Parse error: parse error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING in c:\apache\htdocs\admin\games_report4.php on line 32
Du måste kapsla in eller bryta ut array-variabler i en sträng.
$update = "UPDATE Users SET Users_Points + 4 WHERE Users_UserName = '{$userRow["Tips_UserName"]}'";
// eller
$update = "UPDATE Users SET Users_Points + 4 WHERE Users_UserName = '".$userRow["Tips_UserName"]."'";
270 ms totalt · 4 externa anrop · v20260731065814-full.2f471f9e
128 ms — deklarationer (db)
121 ms — ändringar (db)
