xml parsing.. eller nåt
PHP
6 svar · 418 visningar · startad av UrMe
Medlem sedan apr. 2001762 inlägg
Det ligger till så här att jag har en .xml fil som jag hämtar ut information med hjälp av php.
XML filens uppbyggnad:
<keep name="Caer Renaris" realm="Albion">
  <owner>Albion</owner>
  </keep>
<keep name="Caer Hurbury" realm="Albion">
  <claimant>Lusitania High Council</claimant>
  <claimant_guildurl>No website entered</claimant_guildurl>
  <claimant_heraldurl>tjoho.html</claimant_heraldurl>
</keep>
Sedan kommer php koden här:
<?php
function startElement($parser, $name, $attrs=''){
    global $current_tag,$thename, $therealm;
    $current_tag = $name;
    switch($name){
        case 'KEEP':
		 $thename[]=$attrs['NAME'];
		 $therealm[]=$attrs['REALM'];
        break;
        default:
        break;
function endElement($parser, $name, $attrs=''){
    global $current_tag;
    switch($name){
        case 'OWNER':
        case 'CLAIMANT':
        case 'CLAIMANT_URL':
        case 'CLAIMANT_HERALDURL':
        case 'KEEP':
        $current_tag = '';
        break;
        default:
        break;
function characterData($parser, $data){
    global $current_tag, $theowner, $theclaimant, $theclaimanturl, $theclaimantheraldurl;
    switch($current_tag){
        case 'OWNER':
		 $theowner[]=$data;
		 break;
        case 'CLAIMANT':
		 $theclaimant[]=$data;
		 break;
		 $theclaimanturl[]=$data;
		 break;
		 $theclaimantheraldurl[]=$data;
		 break;
    default:
        break;
$xml_file = xmlfil.xml';
$type = 'UTF-8';
$xml_parser = xml_parser_create($type);
xml_parser_set_option($xml_parser, XML_OPTION_CASE_FOLDING, true);
xml_parser_set_option($xml_parser, XML_OPTION_TARGET_ENCODING, 'UTF-8');
xml_set_element_handler($xml_parser, 'startElement','endElement');
xml_set_character_data_handler($xml_parser, 'characterData');
if (!($fp = fopen($xml_file, 'r'))) {
    die("Could not open $xml_file for parsing!\n");
$xmldata="";
while ($data = fread($fp, 4096)) {
    if (!($data = utf8_encode($data))) {
        echo 'ERROR'."\n";
	$xmldata.=$data;
if (!xml_parse($xml_parser, $xmldata, true)) {
  die("XML error".xml_error_string(xml_get_error_code($xml_parser)));
xml_parser_free($xml_parser);
array_multisort ($therealm, SORT_STRING, $thename, $theowner, $theclaimant, $theclaimanturl, $theclaimantheraldurl);
echo '<table border="1">';
foreach ( $therealm as $key => $value ) {
if($key < 21)
	echo "<tr>";
	echo "<td>$therealm[$key]</td>";
	echo "<td>$thename[$key]</td>";
	echo "<td>$theowner[$key]</td>";
	echo "<td>$theclaimant[$key]</td>";
	echo "<td>$theclaimanturl[$key]</td>";
	echo "<td>$theclaimantheraldurl[$key]</td>";
	echo "</tr>\n";
echo'</table>';
Problemet ligger nu i att om det inte finns nån t.ex "<claimant>" inuti "<keep>" i .xml filen så plockar den nästa "<claimant>" .. och det blir ju inte rätt..
För i detta fall skulle utskriften bli:
Caer Renaris | Albion | Albion | Lusitania High Council | No website entered | tjoho.html
Caer Hurbury | Albion | Albion
Nån som ser problemet? ..
För "Lusutania High Council tillhör ju <keep name="Caer Hurbury">
Åh.. jättesvårt att förklara :)
Fråga om nåt är oklart! ..
Hmmm...
Eftesom $arrayvariabel[]='värde' automatiskt skapar ett nytt indexvärde för just den arrayen just när tilldelningen görs - och inte annars, kommer du i obalans eftersom det medför att den array som inte tilldelas ett värde pga utebliven XML-tagg "hoppar över" ett index så att säga.
Exempel på vad jag menar:
a[]='foo'; b[]='foo' c[]='foo';
a[]='bar; c=[]bar;
a[]='baz'; b[]='baz' c[]='baz';
ger 'bar' 'baz' 'bar' när du plockar ut andra elementet ur respektive array.
Använd något lämplgt indexvärde och se till att den räknas upp i t.ex. startelement och sedan används vid alla tilldelningar.
i startElement:
global $mittindex;
$mittindex=$mittindex+1;
$thename[$mittindex]=$attrs['NAME'];
Efter den ändringen (och naturligtvis en inledande initiering av $mittindex=0 och användning av $mittindex i alla array-tilldelningar ;) ) kommer värden som inte anges att vara tomma i stället.
Det fungerar bra ;) .. nu är det bara ett litet problem..
Om namnet är t.ex:
Olle's bil
Då delar han upp så att han lägger det så här:
$name[] = "Olle";
$name[] = "'";
$name[] = "s bil";
Alltså han bryter vid ' apostrofen... hur gör man för att inte bryta där? ...
För jag vill ju att det ska bli $name[] = "Olle's bil";
Tack på förhand!
*Ute på hal is* ;) - Funkar det om du använder addslashes() vid tilldelningen?
Fast vart ska man lägga in addslashes()? .. om man gör det i funktionerna så blir är det ju redan "försent" .. för då har han redan delat upp strängen. Även fast det läggs ju till en \ före '
EDIT:
Hittade på php.net exakt det problemet jag har:
http://www.php.net/manual/en/function.xml-set-character-data-handler.php
Om ni läser inlägget av ken@positive-edge.com på den sidan.
Men jag blev inte klokare på det :)
Aha, är det *så* den gör!
Det innebär att det tack vare XML-parserns konstruktion inte går att använda "automatisk indexuppdatering vid tilldelning av arrayer" (dvs mittdata[]=$data) i t.ex. characterData(), utan att man måste använda både eget index (se ovan i denna tråd), och vara beredd på att slå ihop strängdatat man får med något som redan kan finnas...
Nånting i stil med
if isset(mittdata[$mittindex]) {
   mittdata[$mittindex].=$data; }
else {
   mittdata[$mittindex]=$data; }
krävs alltså...
Det var som f-n... :birp
Guld ELOGE! Årets medlem :)
TACK!
117 ms — deklarationer (db)
124 ms — ändringar (db)
