ASP till PHP
3 svar · 202 visningar · startad av Squid
SquidMedlem sedan aug. 200228 inlägg
kan någon hjälpa mig med att få den är att bli i php kod den ska arbeta med mysql databas.
IF Request.Querystring("kat") = "" then
kat = "index"
ELSE
kat = Request.Querystring("kat")
END IF
If kat = "index" Then
SQL = "Select TOP 10 * From pc ORDER BY ID DESC"
ElseIf kat = "a" Then
SQL = "Select * From pc Where kat= 'a' ORDER BY fusk_namn asc"
ElseIf kat = "b" Then
SQL = "Select * From pc Where kat= 'b' ORDER BY fusk_namn asc"
ElseIf kat = "c" Then
SQL = "Select * From pc Where kat= 'c' ORDER BY fusk_namn asc"
ElseIf kat = "d" Then
SQL = "Select * From pc Where kat= 'd' ORDER BY fusk_namn asc"
ElseIf kat = "e" Then
SQL = "Select * From pc Where kat= 'e' ORDER BY fusk_namn asc"
ElseIf kat = "f" Then
SQL = "Select * From pc Where kat= 'f' ORDER BY fusk_namn asc"
ElseIf kat = "g" Then
SQL = "Select * From pc Where kat= 'g' ORDER BY fusk_namn asc"
ElseIf kat = "h" Then
SQL = "Select * From pc Where kat= 'h' ORDER BY fusk_namn asc"
ElseIf kat = "i" Then
SQL = "Select * From pc Where kat= 'i' ORDER BY fusk_namn asc"
ElseIf kat = "j" Then
SQL = "Select * From pc Where kat= 'j' ORDER BY fusk_namn asc"
ElseIf kat = "k" Then
SQL = "Select * From pc Where kat= 'k' ORDER BY fusk_namn asc"
ElseIf kat = "l" Then
SQL = "Select * From pc Where kat= 'l' ORDER BY fusk_namn asc"
ElseIf kat = "m" Then
SQL = "Select * From pc Where kat= 'm' ORDER BY fusk_namn asc"
ElseIf kat = "n" Then
SQL = "Select * From pc Where kat= 'n' ORDER BY fusk_namn asc"
ElseIf kat = "o" Then
SQL = "Select * From pc Where kat= 'o' ORDER BY fusk_namn asc"
ElseIf kat = "p" Then
SQL = "Select * From pc Where kat= 'p' ORDER BY fusk_namn asc"
ElseIf kat = "q" Then
SQL = "Select * From pc Where kat= 'q' ORDER BY fusk_namn asc"
ElseIf kat = "r" Then
SQL = "Select * From pc Where kat= 'r' ORDER BY fusk_namn asc"
ElseIf kat = "s" Then
SQL = "Select * From pc Where kat= 's' ORDER BY fusk_namn asc"
ElseIf kat = "t" Then
SQL = "Select * From pc Where kat= 't' ORDER BY fusk_namn asc"
ElseIf kat = "u" Then
SQL = "Select * From pc Where kat= 'u' ORDER BY fusk_namn asc"
ElseIf kat = "v" Then
SQL = "Select * From pc Where kat= 'v' ORDER BY fusk_namn asc"
ElseIf kat = "w" Then
SQL = "Select * From pc Where kat= 'w' ORDER BY fusk_namn asc"
ElseIf kat = "x" Then
SQL = "Select * From pc Where kat= 'x' ORDER BY fusk_namn asc"
ElseIf kat = "y" Then
SQL = "Select * From pc Where kat= 'y' ORDER BY fusk_namn asc"
ElseIf kat = "z" Then
SQL = "Select * From pc Where kat= 'z' ORDER BY fusk_namn asc"
ElseIf kat = "å" Then
SQL = "Select * From pc Where kat= 'å' ORDER BY fusk_namn asc"
ElseIf kat = "ä" Then
SQL = "Select * From pc Where kat= 'ä' ORDER BY fusk_namn asc"
ElseIf kat = "ö" Then
SQL = "Select * From pc Where kat= 'ö' ORDER BY fusk_namn asc"
Set rs= Conn.execute(SQL)
If not rs.eof Then
Do until rs.eof
<a href="pc_consol_fusk_read.asp?ID=<%= rs("ID") %>"><%= rs("fusk_namn") %></a><br>
rs.movenext
Loop
rs.Close
Set rs = Nothing
UlfTMedlem sedan maj 20016 050 inlägg
Jag kan inte hjälpa dig med det du frågar efter, men jag kunde inte låta bli att notera hela harangen av "elseif" som du använder för att bygga upp din sql-sats. Skriv istället:
If kat="index" Then
Else
  SQL = "Select * From pc Where kat='" & kat & "' ORDER BY fusk_namn asc"
Fredde MannenMedlem sedan nov. 20013 498 inlägg
Mamma mia va mycke If satser!!! =)
Hmm... ska väl kunna hjälpa dig lite granna!!! :e
kat = "index"
ELSE
END IF
<?php
// Då kör vi!!!
If($HTTP_GET_VARS["kat"] == "") {
$kat = "index";
} else {
$kat = $HTTP_GET_VARS["kat"];
Den andra delen var det så mycke if-satser!!! :e
Kan väl göras så här på ett förkortat sätt!!!
<?php
If($kat == "index") {
$SQL = "SELECT TOP10 * FROM pc ORDER BY ID DESC";
} else {
$SQL = "SELECT * From pc WHERE kat='$kat' ORDER BY fusk_namn asc";
Nästa del....
If not rs.eof Then
Do until rs.eof
rs.movenext
Loop
rs.Close
Set rs = Nothing
<?php
$result=mysql_query( $SQL );
While( $rad=mysql_fetch_array( $result ) ) {
$ID=rad["ID"];
$fusk_namn=rad["fusk_namn"];
echo "<a href=\"pc_consol_fusk_read.php?ID=".$ID."\">".$fusk_namn."</a></ br>";
Kan hända att jag missat något då.. men men... :birp
If not rs.eof Then
Do until rs.eof
rs.movenext
Loop
rs.Close
Set rs = Nothing
just det... kan ju vara bra att veta hur man kopplar upp sig mot Mysql-databasen!! =)
<?php
@mysql_connect("localhost", "användarnamn","lösenord");
mysql_select_db("dbnamn");
ti hi!!! :OO
Genererad på 506 ms · cache AV · v20260730165559-full.f96bc7eb
