Hämta information
3 svar · 263 visningar · startad av Coper
CoperMedlem sedan mars 2002554 inlägg
nkrantzMedlem sedan apr. 2002830 inlägg
borde funka nu:
<html>
<body>
<?php
$db_=_mysql_connect("localhost",_"root");
mysql_select_db("mydb",$db);
if_(isset($_GET['id']) ||_isset($_POST['id']))
	if_($_POST['submit'])
		$sql_=_"UPDATE_employees_SET first='".$_POST['first']."',last='".$_POST['last']."',address='".$_POST['address']."',position='".$_POST['$position']."'_WHERE_id=".$_POST['id'];
		$result_=_mysql_query($sql);
		echo_"Thank you! Information updated.\n";
	}_
	else_
		// query the DB
		$sql_=_"SELECT_*_FROM_employees_WHERE_id=".$_POST['id'];
		$myrow_=_mysql_fetch_array($result);
		<form method="post" action="<?php_echo_$PHP_SELF?>">
		<input type=hidden name="id" value="<?php_echo_$myrow["id"]_?>">
		First name:<input type="Text" name="first" value="<?php_echo_$myrow["first"]_?>"><br>
		Last name:<input type="Text" name="last" value="<?php_echo_$myrow["last"]_?>"><br>
		Address:<input type="Text" name="address" value="<?php_echo_$myrow["address"]_?>"><br>
		Position:<input type="Text" name="position" value="<?php_echo_$myrow["position"]_?>"><br>
		<input type="Submit" name="submit" value="Enter information">
		<?php
	// display list of employees
	$result_=_mysql_query("SELECT * FROM employees",$db);
	while_($myrow_=_mysql_fetch_array($result))
		printf("<a href=\"%s?id=%s\">%s %s</a><br>\n",_$PHP_SELF,_$myrow["id"],_$myrow["first"],_$myrow["last"]);
</html>
U2KMedlem sedan jan. 2000224 inlägg
Hmm.. det blev en massa _ streck överallt... Bort!
130 ms totalt · 3 externa anrop · v20260731065814-full.3ab8d573
