hjälp!
2 svar · 200 visningar · startad av patrik2002
patrik2002Medlem sedan okt. 2001253 inlägg
hur gör jag för att radbryta strängen efter stor bokstaV?:
$Namn="Kära dagbok.... idag har jag...............................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................";
if (strlen($Namn) > 850){
$str1 = substr ($Namn, 0, 850);
$str2 = substr ($Namn, 851,1900 );
}else{
$str1=$Namn;
$str1 = wordwrap($str1,40, "<br>\n",1);
if(isset($str2)){
$str2 = wordwrap($str2,40, "<br>\n",1);
$stor = preg_replace ( "'([a-zåäö])'is", "<font size=\"20\" face=\"Dauphin\">$1</font>", substr ( $str1, 0, 1 ) );
$stor = strtoupper($stor);
print $stor;
print $str1."<br>";
Ska ett <br /> in efter en stor bokstav, menar du? Låter konstigt, men något sånt här reguljärt uttryck borde fungera:
$str = preg_replace ( "'([A-ZÅÄÖ])'", "$1<br />", $str );
jag sa fel..... för när jag har en stor bokstav tar den upp mer plats än en vanlig bokstav... då blir raden för lång, det jag då vill är att bara radbryta raden efter 36 tecken men resten efter det vanliga
