Län och städer göras om från ASP till PHP
PHP
3 svar · 1 136 visningar · startad av Asa
Medlem sedan dec. 20011 860 inlägg
Någon som kan ändra detta till PHP?
<%Set objRS = Conn.Execute("SELECT hl.lan, sl.id, sl.lanId, sl.Stad FROM fynd_lan hl, fynd_stad sl WHERE hl.id = sl.LanId ORDER BY hl.lan ASC, sl.stad ASC")
   If Not objRS.EOF Then
      '## -- get all links --
      arrLinks = objRS.GetRows()
objRS.Close:Set objRS = Nothing%>
<SCRIPT language="JavaScript">
function boxData(sText, vValue){
	this.text = sText;
	this.value = vValue;
'## -- make arrlinks array to create javascript arrays to populate the second listbox --
If IsArray(arrLinks) Then
	i = 0
	For N = 0 TO UBound(arrLinks,2)
		strLan    = arrLinks(0,N)
		intStadId = arrLinks(1,N)
		intLanId  = arrLinks(2,N)
		strStad   = arrLinks(3,N)
		'## -- print out javascript code to create a new javascript array --
		If intLanId <> intLastLinkID Then
			Response.Write vbcrlf & "var lan" & intLanId & " = new Array();" & vbcrlf
			i = 0
		'## -- print out javascript code to add new values to the javascript array --
		'## -- boxData(listboxtext, listboxvalue.
		'## -- change the asp-variables to suit your needs in text and values --
		Response.Write "lan" & intLanId & "[" & i & "] = new boxData(""" & strStad & """," & intStadId & ");" & vbcrlf
		intLastLinkID = intLanId
		i = i + 1
	Next
function City(obj, icase, arr){
	// alert(icase);
	var vgr = eval (arr);
	if (vgr.length > 0){
		obj.length = (vgr.length + 1);
		obj.options[0].value = '';
		obj.options[0].text = '----- Välj stad -----';
		for(n=0;n<vgr.length;n++){
			obj.options[n+1].value = vgr[n].value;
			obj.options[n+1].text = vgr[n].text;
	}else{
		obj.length = 1;
		for(n=0;n<obj.length;n++){
			obj.options[n].value = 0;
			obj.options[n].text = '----- Välj stad -----';
</SCRIPT>
      <%If IsArray(arrLinks) Then
        intLastLinkID = ""%>
        <SELECT name="county" onChange="City(document.reg.city,this.options.length,value);" style="width:250px">
          <OPTION value="0">---- Välj Län ----</OPTION>
          <%For N = 0 TO UBound(arrLinks,2)
            If intLanId <> intLastLinkID Then%>
              <OPTION value="lan<%=intLanId%>"><%=strLan%></OPTION>
            <%End If
          Next%>
        </SELECT>
      <%End If%>
<br />
      <b> Stad/Ort:</b><br>
      <%If IsArray(arrLinks) Then%>
        <select name="city" style="width:250px">
          <option value="">----- Välj stad -----</option>
        </select>
      <%End If%>
Medlem sedan juni 2009920 inlägg
Ja om du kan ladda upp komplett kod!
Vad jag kan se så är det all ASP kod du behöver, frågan är om inte det hade varit bättre att skriva om koden utan att utgå ifrån äldre Javascript och äldre ASP kod struktur.
Ahh ursäkta det var Tapatalk som skärde bort väldigt mycket kod...
254 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
123 ms — deklarationer (db)
124 ms — ändringar (db)
