BRÅTTOM BEHÖVER HJÄLP
PHPur PHP
3 svar · 1 063 visningar · startad av slex
slexMedlem sedan apr. 201221 inlägg
Hejsan jag har nyss blivit scammad av en snubbe som hjälpte mig med min hemsida. Och han hade bara gjort scripts som inte funkade men jag är ju så dum att jag betalade honom före. Så nu undrar jag om någon här kan ställa upp och när jag har tjänat in 500kr får ni de direkt. Kontakta mig gärna via pm.
1. fix start.php links who has been choosen in links.php will be visible there. add so people can rate and comment too. But they need to have access 1 to do that.
2. fix links.php i want you choose links here and then you are done you click at update. The links will get transfer to start.php
3. include favoriter.php in start and profile i want they make a rate with a star here and the links who has been rated for inlogged user will get it saved in favorites
at profile.php
4. include message system in profile.php the user can send message to other users. And from adminpanel.php i want a admin can send a message to all users with one message.
5. in tips.php i want people only can send links as start with www or http
6. include in start.php if people has click at the link it will be green if not it will be normal color + when people click at the link there will be a new tab. + i want
it shows who made the update with date and time.
7. add lost account for users. add ban system for users with access 2
8. fix the rechaptcha bug in registerer.php and tipsa.php
9. Fix search.php you can search in old_links in database only.
10. mypage.php are the adminpanel only visible for users with access 2
11. settnings.php the users shall only change password and email here.
12. Add news users with access 2 can only add news.
Dies_IraeMedlem sedan aug. 2001145 inlägg
Heh, va? Jag vill ha 5000kr bara för att läsa och förstå va du menar,
Skitsamma 5000kr bara för att hjälpa mig lite? skit ne tack hejdå skiter i hemsidan nu.
Att kanske få 500kr för att fixa alla de punkterna låter tyvärr för lite.
Förstod jag inte ens vad du menade med alla punkter.
Dessutom har posten hamnat lite fel.
122 ms totalt · 3 externa anrop · v20260731065814-full.29ac60f6
119 ms — hämta tråd, inlägg och bilagor (db)
