Hej jag har skapat en wrapper klass till PDO-anslutningen, men jag får fatall error när jag försöker hänta data med den från databasen. Jag använder mig utav php 5.3.2.
db.class.php
<?php
* Database wrapper for PDO
class db extends PDO
public $html = null;
private $_error;
private $_sql;
private $_bind;
private $_errorCallbackFunction;
private $_errorMsgFormat;
* Try to connect to database with PDO
* @param string $dsn
* @param string $user
* @param string $pass
* @param array $options
public function __construct($dsn, $user, $pass, $options="")
// Set default options
$options = array(
PDO::ATTR_PERSISTENT => true,
PDO::ATTR_ERRMODE => PDO::ERRMODE_EXCEPTION
// Try to connect to datase
try {
// Create new PDO object
parent::__construct($dsn, $user, $pass, $options);
} catch (PDOException $e) {
// Add error exception to private variable
$this->_error = $e->getMessage();
* Debuggning PDO error handler
* @return string
private function debug() {
if (!empty($this->_errorCallbackFunction)) {
$error = array("Error" => $this->_error);
// Check if sql query is not empty
if (!empty($this->_sql)) {
$error["SQL Statement"] = $this->_sql;
// Check if any binding exists
if (!empty($this->_bind)) {
$error["Bind Parameters"] = trim(print_r($this->_bind, true));
// Generate backtrace
$backtrace = debug_backtrace();
// Create backtrace information
if (!empty($backtrace)) {
foreach($backtrace as $info) {
if ($info["file"] != __FILE__) {
$error["Backtrace"] = $info["file"]." @ ".$info["line"];
// Check if error-message format is html
if ($this->_errorMsgFormat == "html") {
// Check if any bind errors exist
if (!empty($error["Bind Parameters"])) {
$error["Bind Parameters"] = "<pre>".$error["Bind Parameters"]."</pre>";
// Get stylesheet file
$css = trim(file_get_contents(dirname(__FILE__)."/error.css"));
// html error output
$this->html = "<style>\n$css\n</style>\n";
$this->html .= '<div class="db-error">';"\n<h3>SQL Error</h3>";
$this->html .= '<table><thead>';
$this->html .= '<tr><th>Key</th><th>Value</th></tr></thead>';
$this->html .= '<tbody><tr>';
foreach ($error as $key => $val) {
$this->html .= "<td>$key</td>\n<td>$val</td>";
$this->html .= "</tr></tbody></table></div>";
// Else if message-format is html
elseif($this->_errorMsgFormat == "text") {
$msg .= "SQL Error\n" . str_repeat("-", 50);
foreach($error as $key => $val)
$msg .= "\n\n$key:\n$val";
return $this->_errorCallbackFunction($msg);
} else {
return false;
* Delete data from database
* @param string $table
* @param string $where
* @param array $bind
* @return boolean
public function delete($table, $where, $bind="") {
// Crate database query
$sql = "DELETE FROM " . $table . " WHERE " . $where . ";";
// Run query
if ($this->run($sql, $bind)) {
// If everything went fine, return true
return true;
else {
// If an error occurred in the process, return false
return false;
* Filter data
* @param string $info
* @return array
private function filter($table, $info) {
// Collect pdo driver data
$driver = $this->getAttribute(PDO::ATTR_DRIVER_NAME);
// If using SQLite as driver
if ($driver == 'sqlite') {
$sql = "PRAGMA table_info('" . $table . "');";
$key = "name";
// If using MySQL as driver
else if ($driver == 'mysql') {
$sql = "DESCRIBE " . $table . ";";
$key = "Field";
// For all other driver
else {
$sql = "SELECT
column_name
FROM
information_schema.columns
WHERE table_name = '" . $table . "';";
$key = "column_name";
// Check if value is false
if (false !== ($list = $this->run($sql))) {
// Create array
$fields = array();
// Save list values in $fields array
foreach ($list as $record) {
$fields[] = $record[$key];
return array_values(array_intersect($fields, array_keys($info)));
return array();
* Clean up array
* @return array
private function cleanup($bind) {
// Check if isn't an array
if(!is_array($bind)) {
// Check if the variable is empty
if (!empty($bind)) {
$bind = array($bind);
// Else create an array
else {
$bind = array();
return $bind;
* Insert data into database
* @param <type> $table
* @param <type> $info
* @return <type>
public function insert($table, $info) {
// Filter table and info
$fields = $this->filter($table, $info);
// Create sql query
$sql = "INSERT INTO ".$table." (".implode($fields, ", ");
$sql .= ") VALUES (:".implode($fields, ", :").");";
// Create an array for bindings
$bind = array();
// Add table and info variables to array
foreach ($fields as $field) {
$bind[":$field"] = $info[$field];
return $this->run($sql, $bind);
* Execute SQL query
* @param string $sql
* @param string $bind
* @return mixed
public function run($sql, $bind="") {
// Declare no errors
$this->_error = null;
// Trim query
$this->_sql = trim($sql);
// Clean up
$this->_bind = $this->cleanup($bind);
// Try execute sql query
try {
// Prepare query
$stmt = $this->prepare($this->_sql);
// If binding execution not fails
if ($stmt->execute($this->_bind) !== false) {
// Match 'select', 'describe' or 'pragma' in query
if (preg_match("/^(" .
implode("|",
array(
"select",
"describe",
"pragma")) . ") /i", $this->_sql)) {
// Return array fetch all
return $stmt->fetchAll(PDO::FETCH_ASSOC);
// Match 'delete', 'insert' or 'update' in query
else if (preg_match("/^(".
implode("|",
array(
"delete",
"insert",
"update")) . ") /i", $this->_sql)) {
// Return row count
return $stmt->rowCount();
// Catch any exceptions
// Get error message
// Get debugging
$this->debug();
return false;
* Select data from database
* @param string $fields
* @return mixed
public function select($table, $where="", $bind="", $fields="*") {
// Create 'SELECT' query
$sql = "SELECT " . $fields . " FROM " . $table;
// Check if any WHERE statements
if (!empty($where)) {
$sql .= " WHERE " . $where;
// End sql query
$sql .= ";";
// Return execute query
* Set error callback function
* @param string $errorCallbackFunction
* @param string $errorMsgFormat
* @return string
public function setErrorCallbackFunction($errorCallbackFunction,
$errorMsgFormat="html") {
// Variable functions for won't work with language constructs such as
// echo and print, so these are replaced with print_r.
if(in_array(strtolower($errorCallbackFunction),
array("echo", "print"))){
$errorCallbackFunction = "print_r";
// Check if function exists
if(function_exists($errorCallbackFunction)) {
// Collect callback function data
$this->_errorCallbackFunction = $errorCallbackFunction;
// If $errorMsgFormat isn't either html or text , default html
if(!in_array(strtolower($errorMsgFormat), array("html", "text"))) {
$errorMsgFormat = "html";
// Return error message
return $this->_errorMsgFormat = $errorMsgFormat;
* Update data in database
* @return mixed
public function update($table, $info, $where, $bind="") {
// Collect filter data
// Calculate size of array
$fieldSize = sizeof($fields);
// Create update query string
$sql = "UPDATE " . $table . " SET ";
// Loop adding query from array
for ($f = 0; $f < $fieldSize; ++$f) {
// If array hold more then one value
if ($f > 0) {
$sql .= ", ";
// Add query string
$sql .= $fields[$f] . " = :update_" . $fields[$f];
// End query string
$sql .= " WHERE " . $where . ";";
// Cleanup bindings
$bind = $this->cleanup($bind);
// Loop update array
$bind[":update_$field"] = $info[$field];
// Return execute process
Sen på min index.php test-sida för tillfälligt har jag denna kod;
<?php
// Aktivera felrapportering
error_reporting(E_ALL);
// Hämta configs
$app = parse_ini_file('configs/application.ini');
// Hämta klass
require_once '../resources/class/db.class.php';
// Definiera DSN med config-variablerna
$dsn = $app['db.type'];':host='.$app['db.host'].';';
$dsn .= 'port='.$app['db.port'].';';
$dsn .= 'dbname='.$app['db.name'];
// Skapa ny databas anslutning
$db = new db($dsn, $app['db.user'], $app['db.pass']);
// Denna kör koden; 'SELECT' * FROM 'users' och sparar till $results
// Denna raden skapar problemet!!
$results = $db->select("users");
När jag kör min kod får jag detta problemet:
Fatal error: Call to a member function select() on a non-object in index.php on line 20
Vad är det som skapar detta problemet och hur löser man det?, jag skapade väll ett pdo-objekt i konstruktorn?
