Fel: session_start() : File too large (27)
PHP
8 svar · 1 051 visningar · startad av Tibbelit
Medlem sedan mars 200986 inlägg
Warning: session_start() [function.session-start]: open(/storage/configuration/php_session_path/sess_4172230e823c4c3d49f912b88d73cf3d, O_RDWR) failed: File too large (27) in /storage/content/22/102322/tibbelit.se/public_html/film/head.php on line 2
Hur kan det bli så? Hur kan jag lösa det?
Det kom helt plötsligt på en hemsida jag gjort idag :S Skumt tycker jag!
Edit: Det kommer fler del (men beror nog på raden ovan):
Warning: session_start() [function.session-start]: open(/storage/configuration/php_session_path/sess_ef7640c7036f1eaea305c41f633778c9, O_RDWR) failed: File too large (27) in /storage/content/22/102322/tibbelit.se/public_html/film/loginproc.php on line 2
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /storage/content/22/102322/tibbelit.se/public_html/film/loginproc.php:2) in /storage/content/22/102322/tibbelit.se/public_html/film/loginproc.php on line 2
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /storage/content/22/102322/tibbelit.se/public_html/film/loginproc.php:2) in /storage/content/22/102322/tibbelit.se/public_html/film/loginproc.php on line 2
Warning: Cannot modify header information - headers already sent by (output started at /storage/content/22/102322/tibbelit.se/public_html/film/loginproc.php:2) in /storage/content/22/102322/tibbelit.se/public_html/film/loginproc.php on line 12
Warning: Unknown: open(/storage/configuration/php_session_path/sess_ef7640c7036f1eaea305c41f633778c9, O_RDWR) failed: File too large (27) in Unknown on line 0
Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/storage/configuration/php_session_path) in Unknown on line 0
Lagrar du mycket i sessionsvariablerna? Låter som att du slagit i taket på hur mycket du kan lagra i sessionsvariablerna.
Kan också vara så att disken är full där du och alla andra som kör på samma server lagrar sina sessiondata.
Det enda som jag "aktivt" sparar i sessionsvariablerna är användarnamnet samt vilken "nivå" som denne är. Alltså typ:
$_SESSION['username']; och $_SESSION['userlevel'];
Men vad mer sparas i sessionen som jag inte "aktivt" själv sparar? Det är kanske där skon klämmer?
Edit: Kom inte fram på denna datorn nu, men gör det fortfarande på min andra dator. Skumt!
Länk till sidan (om det hjälper): http://www.tibbelit.se/film/
Medlem sedan mars 2006296 inlägg
Sjukt! Vi/Jobbet har haft exakt samma fel på en av sajterna och den ligger också på Binero 2.0 servern...
CMSet vi kör har aldrig haft det här problemet förut heller...
Medlem sedan nov. 2000146 inlägg
Även jag har fått rapporter från en kund som jag har gjort en sida åt att denne fått dessa felmeddelanden under dagen, även han ligger på Binero 2.0
Medlem sedan juni 20031 837 inlägg
Upptäckte att jag också har fått samma felmeddelande för några webbplatser hos Binero 2.
Tibbelit, ligger din webbplats hos Binero?
Japp det gör den!
Får du fortfarande problem? Vi gjorde en justering för att lösa detta i förrgår.
Aha! Felet uppkom lite sporadiskt så det är svårt att säga, men jag har inte sett det på ett tag nu.
Tackar! :)
264 ms totalt · 4 externa anrop · v20260731065814-full.2f471f9e
123 ms — deklarationer (db)
126 ms — ändringar (db)
