Testar registreringsformulär men mitt echo funkar inte.. :(
PHP
22 svar · 995 visningar · startad av Mycodez
Medlem sedan feb. 2010445 inlägg
Hej..
som titlen säger så har jag ett problem med att echo ut lite funktion
<?php
include('design/header.php');
require('connect.php');
//REGISTER CODE
//Grab submitted data
if($_POST['$submit'])
	// Grabb submitted data
	$firstname = 			$_POST['firstname'];
	$lastname = 			$_POST['lastname'];
	$username = 			$_POST['username'];
	$password = 			$_POST['password'];
	$password_repeat = 		$_POST['password_repeat'];
	$dob_year = 			$_POST['dob_year'];
	$dob_month = 			$_POST['dob_month'];
	$dob_day = 				$_POST['dob_day'];
	$gender = 				$_POST['gender'];
	if
	$firstname&&
	$lastname&&
	$username&&
	$password&&
	$password_repeat&&
	$dob_year&&
	$dob_month&&
	$dob_day&&
	$gender
		echo"allt lagrat";
	echo"Missing field! Please fill in all fields!";
	echo"Please enter your details and click Register.";
<form action='register.php' method='post'>
<p>
<table width='100%'>
<tr>
	<td width='50%' align='right'>
    <font size='2' face='arial'>Firstname:</font>
    </td>
    <td>
    <input type='text' namae='firstname' maxlength='25'>
    </td>
</tr>
<tr>
    <font size='2' face='arial'>Lastname:</font>
    </td>
    <td>
    <input type='text' namae='lastname' maxlength='25'>
    </td>
</tr>
<tr>
    <font size='2' face='arial'>Username:</font>
    </td>
    <td>
    <input type='text' namae='username' maxlength='25'>
    </td>
</tr>
<tr>
    <font size='2' face='arial'>Password:</font>
    </td>
    <td>
    <input type='password' namae='password' maxlength='25'>
    </td>
</tr>
<tr>
    <font size='2' face='arial'>Repeat password:</font>
    </td>
    <td>
    <input type='password' namae='password_repeat' maxlength='25'>
    </td>
</tr>
<tr>
    <font size='2' face='arial'>Date of birth:</font>
    </td>
    <td>
    <input type='text' namae='dob_year' maxlength='4' size='3' value='YYYY'> /
    <input type='text' namae='dob_month' maxlength='2' size='1' value='MM'> /
    <input type='text' namae='dob_day' maxlength='2' size='1' value='DD'>
    </td>
</tr>
<tr>
    <font size='2' face='arial'>Gender:</font>
    </td>
    <td>
    <select name='gender'>
    	<option>Female</option>
        <option>Male</option>
    </select>
    </td>
</tr>
</table>
</p>
<div  align='right'><input type='submit' namae='submit' value='Register'></div>
<?php
include('design/footer.php');
Det ända som blir echo är
jag är ny i php så ni vet
mycket tacksam för snabba svar och liten beskrivning på felet tack
/ MMycodez
http://www.mycodez.se - bloggen
Idé 3D uf - mitt uf företag
Medlem sedan jan. 2005953 inlägg
Du har skrivit namae='submit' på din submit-knapp. Ändra till name='submit'
tack dock ett mkt enkelt svar
Den vill fortfarande inte skriva ut mitt echo meddelande :(
Det är bara det echot som visar sig hela tiden
Ändra
till
if($_POST['submit'])
Det händer fortfarande ingen skillnad :(
Alltså vart kan felet sitta i mitt echo meddelande?
<?php
//Register code
if
	$firstname&&
	$lastname&&
	$username&&
	$password&&
	$password_repeat&&
	$dob_year&&
	$dob_month&&
	$dob_day&&
	$gender
		echo "allt lagrat";
	echo "Missing field! Please fill in all fields!";
	echo "Please enter your details and click Register.";
<form action='register.php' metohod='POST'>
	<table width='60%'>
		<tr>
        	<td width='40%' align='right'>
			</td>
			<td>
				<input type='text' name='firstname' maxlength='25'>
        	</td>
		</tr>
		<tr>
			</td>
			<td>
				<input type='text' name='lastname' maxlength='25'>
        	</td>
		</tr>
		<tr>
			</td>
			<td>
				<input type='text' name='username' maxlength='25'>
        	</td>
		</tr>
		<tr>
			</td>
			<td>
				<input type='password' name='password' maxlength='25'>
        	</td>
		</tr>
        <tr>
			</td>
			<td>
				<input type='password' name='password_repeat' maxlength='25'>
        	</td>
		</tr>
		<tr>
    		</td>
    		<td>
    		</td>
		</tr>
		<tr>
    		</td>
    		<td>
    			</select>
    		</td>
		</tr>
</table>
<div  align='right'><input type='submit' name='submit' value='Register'></div>
	</table>
<?php
Alltså har jag skrivit något gallet? har jag glömt tecken elelr vad e det för fel blir snart crazy
Medlem sedan juni 2009920 inlägg
Ändra
till
if(isset($_POST['submit']))
Du måste också fixa till denna kod
if
	$firstname&&
	$lastname&&
	$username&&
	$password&&
	$password_repeat&&
	$dob_year&&
	$dob_month&&
	$dob_day&&
	$gender
Det funkar bara att skriva så om tex $firstname är sant eller falskt. Inte som sträng. Så du måste wrappa dom med isset, eller empty. Annars blir det fel.
Du har ändrat lite från dit första inlägg. T.ex ändrat "method" till "metohod", vilket gör att du inte får med några värden alls... Du har även dubbla sluttaggar för "table" och "form".
Min första tanke också, men vid en testkörning visade det sig fungera alldeles utmärkt. (PHP 5.3.1)
Gildebrand skrev:
Ändra
till
if
	$firstname&&
	$lastname&&
	$username&&
	$password&&
	$password_repeat&&
	$dob_year&&
	$dob_month&&
	$dob_day&&
	$gender
Okej Vad gör det dära isset??
if
    isset($firstname)&&
    isset($lastname)&&
    isset($username)&&
    ...osv...
Kolla så att du har ändrat alla "namea" till "name". ;)
okej men jag har ändat allt nu och så till och med satt dit isset men nu så kommer inte echot ut utan allt skrivs ut i urlfältet vad e det för galet då?
Ja du. Har du ändrat till method som fiddler skrev i går?
Om man anger "metohod" istället för "method" så blir resultatet att man inte har angett method, och då skickas allt i url:en eftersom "get" är default.
oj det hade jag visst inte gjort men nu så funkar det ;) Tack så mycket:) men jGa gör funktion isset? egentligen vet om man sätter den i if satsen så gör den allt till isset men vad gör själva Isset funktionen?
Manualet på php.net är finfin.
Enligt http://se2.php.net/manual/en/function.isset.php använder man isset för att kontrollera att en variabel har ett värde (som är skilt från null).
Medlem sedan juni 20031 837 inlägg
istället för att anropa isset flera gånger kan man skriva följande:
if (isset($firstname, $lastname, $username, $password, $password_repeat, $dob_year, $dob_month, $dob_day, $gender) )
Fast variablerna kommer ju ändå få ett "värde" även fast $_POST är tom. Så isset där funkar väl inte? Du får isf. köra isset($_POST['firstname'])... Alt kolla strlen($firstname)
Bättre att köra med "empty" kanske.
256 ms totalt · 4 externa anrop · v20260731065814-full.6fe65c25
121 ms — deklarationer (db)
121 ms — ändringar (db)
