Vad är felet?
2 svar · 627 visningar · startad av Mycodez
MycodezMedlem sedan feb. 2010445 inlägg
Hej jag försöker göra en koll om en användare redan finns i min databas
jag får detta felmeddelande:
Warning: mysql_num_rows(): supplied argument is not a valid MySQL result resource in /home/web77725l/domains/mycodez.se/public_html/testing/register.php on line 19
rad 19:
		$count = mysql_num_rows($namecheck);
och här är hela koden
<?php
	echo "<h1>Register</h1>";
	$submit = $_POST['submit'];
	//Form data
	$fullname = strip_tags($_POST['fullname']);
	$username = strtolower(strip_tags($_POST['username']));
	$password = strip_tags($_POST['password']);
	$repeatpassword =strip_tags($_POST['repeatpassword']);
	$date = date("Y-m-d");
if ($submit)
		// open database
		$connect = mysql_connect("mysql66.kontrollpanelen.se","******","******");
		mysql_select_db("web77725l_php");//select database
		$namecheck = mysql_query("SELECT username FROM WHERE username='$username'");
		echo $count;
		die();
	//Check for exiistance
	if ($fullname&&$username&&$password&&$repeatpassword)
	if($password==$repeatpassword)
		// check char length of username and fullname
		if(strlen($username)>25||strlen($fullname)>25)
			echo "Length of username or fullname is too long!";
		if (strlen($password)>25||strlen($password)<6)
			echo "Password must be between 6 adn 25 characters";
		//register the user!
		//encrypt password
		$password = md5($password);
		$repeatpassword = md5($repeatpassword);
		// open database
		$connect = mysql_connect("mysql66.kontrollpanelen.se","web77725l_admin","flagga");
		$queryreg = mysql_query("
		INSERT INTO users VALUES ('','$fullname','$username','$password','$date')");
						die("You have been registered! <a href='index.php'>Return to login page</a>");
		echo "Your password do not match!";
		echo "Please fill in <b>all</b> fields!";
<html>
<p>
<form action='register.php' method='POST'>
	<table>
    	<tr>
        	<td>
            Your full name:
            </td>
        	<td>
            <input type='text' name='fullname' value='<?php echo $fullname; ?>'>
            </td>
        </tr>
      	<tr>
        	<td>
            Choose a username:
            </td>
        	<td>
            <input type='text' name='username'value='<?php echo $username; ?>'>
            </td>
        </tr>
        <tr>
        	<td>
            Choose a password:
            </td>
        	<td>
            <input type='password' name='password'>
            </td>
        </tr>
     	<tr>
        	<td>
            Repeat your password:
            </td>
        	<td>
            <input type='password' name='repeatpassword'>
            </td>
        </tr>
    </table>
    <p>
    <input type='submit' name='submit' value='Register'>
    </p>
</p>
</html>
mycket tacksam för snabba svar
/Robin
http://www.mycodez.se --- min blogg
Du har inte angett någon tabell i din sql-fråga.
Tänk lite på att skriva en lite mer beskrivande trådrubrik.
Tack så mycket. Okej ska tänka på det till nästa gång :)
130 ms totalt · 3 externa anrop · v20260731065814-full.beb2e261
