Får detta när jag har använt w3c validator
w3c validator skrev:
You have used a character that is not considered a "name character" in an attribute value. Which characters are considered "name characters" varies between the different document types, but a good rule of thumb is that unless the value contains only lower or upper case letters in the range a-z you must put quotation marks around the value. In fact, unless you have extreme file size requirements it is a very very good idea to always put quote marks around your attribute values. It is never wrong to do so, and very often it is absolutely necessary.
Vart ska jag sätta citattecknen någon stans
här är den han klagar på
echo "<a href=".htmlspecialchars($row['lank'])."?rakna=$iv>".htmlspecialchars($row['namn'])."</a><br>";
