Tack, men det blir fortfarande problem, har antagligen missat något annat.. får fortfarande fel. skulle uppskatta om detta kunde lösas suttit väldigt länge med detta. Tack ännu en gång för ditt svar ;)
Parse error: syntax error, unexpected ',' in line 49
ps. jo jag använder en beta php text editor
function db_connect(){
global $db_server;
global $db_name;
global $db_username;
global $db_password;
$con =@ mysql_connect($db_server,$db_username,$db_password);
if ($con!=false){
if (!(mysql_select_db($db_name,$con))){
// cannot find database
die("Cannot find Database");
} else {
// fine
} else {
die ("Cannot connect to database");
return $con;
function db_search($key) {
$con = db_connect();
$key = mysql_escape_string($key);
$sql = "SELECT DISTINCT namn FROM annonser WHERE namn LIKE '%".$bil."%'";
$result = mysql_query($sql,$con);
mysql_close($con);
return $result;
if(isset($_REQUEST['key']))
$key = $_REQUEST['key'];
$result = db_search_bible($key);
if($result == FALSE)
$content = 'No Match Found';
while ($row = mysql_fetch_row($result)) {
$content .= '.$row[0].', '.$row[1].', '.$row[2].', '.$row[3].'<br>;
echo $content;
$html = '<html><head><title>Search Results</title></head><body><table border=0 width=”200px”>'<!--content-->'</table></body></html>';
$content = '<tr><td>No Match Found</td></tr>';
$content = 'Found';
$content .= '<tr><td><h2>'.$row[0].'</h2> <br><br>'.$row[1].'</td></tr>';
$html = str_replace('<!--content-->'),$content,$html);
echo $html;
