Sökmotorvänligt hur??
PHP
4 svar · 538 visningar · startad av ponting
Medlem sedan sep. 2004111 inlägg
Jag håller på en liten bookmarks: http://lankbase.linkeater.tk
men den är ej seo vänlig, hur gör jag om,redict.php så det blir seo vänligt??
Koden ser ut så här:
<?php
/* $Id: redirect.php,v 1.12 2005/10/19 07:12:35 dbu Exp $
Task: increment the 'hit counter' of the right link and redirect the user to
the correct URL
LinkBase
A web application (written in PHP) that helps to manage the Internet bookmarks
of an organisation (such as a company, a school...) by centralizing those
links in a single multi-user database (SQL). You can then access this base
with a web browser.
Copyright (C) 2003-2005 David BUCHMANN <budda@budda.ch>
Copyright (C) 2001-2003 Jean HAUSSER <jhausser@tuxfamily.org>
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
as published by the Free Software Foundation; either version 2
of the License, or (at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program; if not, write to the Free Software
Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
error_reporting(E_ALL); //fixme: only for debugging
require_once('inc/common.inc.php');
//calls a function in common.inc.php which does initialization, sanity check and session management
$lb_error = lb_init();
if ($lb_error) {
echo '<html><head><title>Error</title></head>'.
'<body><p>Severe configuration error: '.$lb_error.
'</p></body></html>';
exit();
if ( isset($_REQUEST['id']) ) {
//this is no method, so global is not needed, but for info:
//global $lb_session, $lb_config, $lb_lang, $lb_linkdb;
if (! $lb_session->canView($lb_linkdb->getOwnerOfLink($_REQUEST['id']))) {
echo '<html><head><title>Error</title></head><body>';
echo $lb_theme->error($lb_lang['access_denied_error']);
echo '</body></html>';
exit();
$link = $lb_linkdb->getLink($_REQUEST['id']);
if ( ! $link ) {
echo $lb_theme->error($lb_lang['displink_error']);
echo '</h1></body></html>';
exit();
$is_down = ($link['down_since'] > 0);
$check_needed = ( ( time() - $link['last_checked']) / (60*60*24) >=
$lb_config['url_check_interval'] );
if ($check_needed || $is_down) {
$is_down = ! $lb_linkdb->checkUrl($_REQUEST['id'], $link[6], $link[9], true);
if (! $is_down ) {
$lb_linkdb->updateLinkHits($link['id']);
if (strstr($link\['url'\], ';') === FALSE) {
    header('Location: '.  $link\['url'\]); // redirect to the website
    echo '\<html\>\<head\>\<title\>LinkBase Redirect\</title\>\</head\>\<body\>';
} else {
    //do no automatic redirect for unicode urls. they are encoded as html, thus would have a ; in the location: header, which the browser does not like.
    echo '\<html\>\<head\>\<title\>LinkBase Redirect\</title\>';
    echo '\<meta http-equiv="REFRESH" content="0;url='.$link\['url'\]. '"\>';
    echo '\</head\>\<body\>';
echo 	'\<a href="'.$link\['url'\].'"\>'.$link\['title'\].'\</a\>'.
'\</body\>\</html\>';
} else { // a unsuccessful check was performed
  echo '\<html\>\<head\>\<title\>LinkBase\</title\>\</head\>\<body\>'.
'\<a href="'.$link\['url'\].'"\>'.$link\['title'\].'\</a\> '.$lb_lang\['site_down'\].' '.
$lb_config\['url_check_maxdowntime'\].' '.$lb_lang\['days'\].
} else {
header('Location: ./'); //no link specified, go to index
nån som vore bussig och kan hjälpa mig??
Medlem sedan mars 2007845 inlägg
Det vore mycket lättare att läsa om du använt code-taggen.
Medlem sedan mars 200921 inlägg
.. och allt som borde postats är...
if (strstr($link['url'], ';') === FALSE) {
header('Location: '. $link['url']); // redirect to the website
echo '<html><head><title>LinkBase Redirect</title></head><body>';
} else {
echo '<html><head><title>LinkBase Redirect</title>';
echo '<meta http-equiv="REFRESH" content="0;url='.$link['url']. '">';
echo '</head><body>';
echo '<a href="'.$link['url'].'">'.$link['title'].'</a>'.
'</body></html>';
echo '<html><head><title>LinkBase</title></head><body>'.
'<a href="'.$link['url'].'">'.$link['title'].'</a> '.$lb_lang['site_down'].' '.
$lb_config['url_check_maxdowntime'].' '.$lb_lang['days'].
'</body></html>';
Men det spelar ingen roll hurvida redirect funktionen är SEO vänlig eller ej med REFRESH värde noll. Problemet är att ingen av sidorna är särskilt SEO vänliga. Ett litet försök har gjorts med att skriva <h1> lite här och var (på gränsen till spam). Meta name/descriptions saknas, struktur saknas, m.m. Om du insisterar på att göra det själv så köp en bok om SEO, finns lite för mycket att nämna.
OK, då skiter jag i det och gör en: PHP LD som vanligt. Tack för hjälpen i alla fall.
Medlem sedan maj 2010117 inlägg
Den enda redirect som är måttligt bättre än andra redirects (alla är dåliga ur SEO-perspektiv) är en 301 (moved permanently):
<?php
// Permanent redirection
header("HTTP/1.1 301 Moved Permanently");
header("Location: http://www.example.com/");
exit();
Detta säger alltså till sökmotorn att ALLTID du besöker denna sida är det en redirect till den andra sidan. Google har höjt 302 till att vara bättre än 301 (moved temporarily). 302 är annars den som vanligast genereras om man i script-språk ber om en redirect, 301 måste man explicit ange.
265 ms totalt · 4 externa anrop · v20260731065814-full.6fe65c25
129 ms — deklarationer (db)
130 ms — ändringar (db)
