Hjälp med vattenstämpel
PHP
0 svar · 320 visningar · startad av Guldstrand
Medlem sedan juli 20041 271 inlägg
Någon som kan hjälpa mig med att lägga till en funktion för vattenstämpel (watermark) i scriptet nedan!?
<?php
# Constants
define(IMAGE_BASE, 'images/fargbilder/stor/');
define(MAX_WIDTH, 400);
define(MAX_HEIGHT, 300);
# Get image location
$image_file = str_replace('..', '', $_SERVER['QUERY_STRING']);
$image_path = IMAGE_BASE . "/$image_file";
# Load image
$img = null;
$ext = strtolower(end(explode('.', $image_path)));
if ($ext == 'jpg' || $ext == 'jpeg') {
    $img = @imagecreatefromjpeg($image_path);
} else if ($ext == 'png') {
    $img = @imagecreatefrompng($image_path);
# Only if your version of GD includes GIF support
} else if ($ext == 'gif') {
    $img = @imagecreatefromgif($image_path);
# If an image was successfully loaded, test the image for size
if ($img) {
    # Get image size and scale ratio
    $width = imagesx($img);
    $height = imagesy($img);
    $scale = min(MAX_WIDTH/$width, MAX_HEIGHT/$height);
    # If the image is larger than the max shrink it
    if ($scale < 1) {
        $new_width = floor($scale*$width);
        $new_height = floor($scale*$height);
        # Create a new temporary image
        $tmp_img = imagecreatetruecolor($new_width, $new_height);
        # Copy and resize old image into new image
        imagecopyresized($tmp_img, $img, 0, 0, 0, 0,
                         $new_width, $new_height, $width, $height);
        imagedestroy($img);
        $img = $tmp_img;
# Create error image if necessary
if (!$img) {
    $img = imagecreate(MAX_WIDTH, MAX_HEIGHT);
    imagecolorallocate($img,0,0,0);
    $c = imagecolorallocate($img,90,90,90);
    imageline($img,0,0,MAX_WIDTH,MAX_HEIGHT,$c2);
    imageline($img,MAX_WIDTH,0,0,MAX_HEIGHT,$c2);
# Display the image
header("Content-type: image/jpeg");
imagejpeg($img);
Tack på förhand! :birp
253 ms totalt · 4 externa anrop · v20260731065814-full.6fe65c25
124 ms — deklarationer (db)
123 ms — ändringar (db)
