unexpected T_VARIABLE
2 svar · 438 visningar · startad av yador
yadorMedlem sedan mars 2004455 inlägg
Hejsan!
Så här ser page.php ut
<?php
class Page {
	var $dtd;
	var $title;
	var $meta;
	var $csslink;
	var $script;
	var $body;
	function Page() {
		$this->dtd = "<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.1//EN\" \"http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd\">";
	function setDTD($dtd){
		$this->dtd = $dtd;
	function getDTD(){
		return $this->dtd;
	function setTitle($title){
		$this->title = $title;
	function getTitle(){
		return $this->title;
	function metaSize(){
		$i = 0;
		while(isset($this->meta[$i])) {
			$i++;
		return $i;
	function addMetaTag($metatag){
		$this->meta[$this->metaSize()+1] = $metatag;
	function eraseMetaTag($which = All){
		if($which == "All"){
			$this->meta = "";
			return;
		if(!is_numeric($which)){
			return;
		$copy;
		$i;
		for($i=0;$i<$which;$i++){
			$copy[$i] = $this->meta[$i];
		$i++;
			$copy[$i-1] = $this->meta[$i];
	function getMetaTag($which = ALL){
		if($which == "ALL"){
			$ret;
			$i = 0;
				$ret = $ret - $this->meta[$i];
				$i++;
			return ret;
		if(is_numeric($which) && isset($this->meta[$which])){
			return $this->meta[$which];
	function addCssLink($csslink){
		$this->csslink = $this->csslink . $csslink;
	function eraseCssLinks(){
		$this->csslink = "";
	function draw() {
		print $this->dtd . "\n";
		print "<html>\n";
		print "<head>\n";
		if(isset($this->title)){
			print "<title>" . $this->title . "</title>\n";
		if(isset($this->meta)){
		print $this->meta . "\n";
		if(isset($this->csslink) && $this->csslink != ""){
			print "<link rel=\"stylesheet\" type=\"text/css\" href=\"" . $this->csslink . "\" />\n";
		if(isset($this->script)){
		print $this->script . "\n";
		print "</head>\n";
		print "<body>\n";
		print $this->body;
		print "</body>\n";
		print "</html>\n";
class XPage {
	$page = new Page();
Och såhär ser index.php ut.
require("../classes/page.php");
$a = new XPage();
Och detta felet får jag:
Parse error: syntax error, unexpected T_VARIABLE, expecting T_FUNCTION in /srv/www/htdocs/hemsidor/projektx/classes/page.php on line 111
Hur kan jag åtgärda det? Håller nämligen på att lära mig php och förstår ingenting.
Tack på förhand!
<?php
class Page {
	var $dtd;
	var $title;
	var $meta;
	var $csslink;
	var $script;
	var $body;
	function Page() {
		$this->dtd = $dtd;
	function getDTD(){
		return $this->dtd;
		$i = 0;
			$i++;
		return $i;
			$this->meta = "";
			return;
			return;
		$copy;
		$i;
		$i++;
			$ret;
			$i = 0;
				$i++;
			return ret;
	function draw() {
		print "<html>\n";
		print "<head>\n";
		print "</head>\n";
		print "<body>\n";
		print $this->body;
		print "</body>\n";
		print "</html>\n";
class XPage {
	var $page;
	function XPage() {
	$this->page=new Page();
Tack!
127 ms totalt · 3 externa anrop · v20260731065814-full.2b84b982
