Radera bild från servern + sökväg i mysql?
PHP
1 svar · 386 visningar · startad av Guldstrand
Medlem sedan juli 20041 271 inlägg
Har lite problem med att radera en bild från servern med unlink().
Varken bilden i mappen eller sökvägen i mysql raderas.
Detta finns:
	$path = "/home/var/*****/*****/userpics/profilbilder/$CURUSER[username]";
          if (get_user_class() >= UC_MODERATOR || $a["userid"] == $CURUSER["id"]) {
		$delete = $HTTP_GET_VARS["delete"];
		if (is_valid_id($delete)) {
			$r = mysql_query("SELECT * FROM profilbilder WHERE picid=$delete") or sqlerr(__FILE__, __LINE__);
			if (mysql_num_rows($r) == 1) {
				$a = mysql_fetch_assoc($r);
					mysql_query("DELETE FROM profilbilder WHERE picid=$delete") or sqlerr(__FILE__, __LINE__);
					if (!unlink("$path/$a[location]"))
						stderr("Warning", "Unable to unlink file: <b>$a[location]</b>. You should contact an administrator about this error.");
	stdhead("BitBucket Log");
	$res = mysql_query("SELECT count(*) FROM profilbilder WHERE userid = $CURUSER[id]") or die(mysql_error());
	$row = mysql_fetch_array($res);
	$count = $row[0];
	$perpage = 10;
	list($pagertop, $pagerbottom, $limit) = pager($perpage, $count, $_SERVER["PHP_SELF"] . "?out=" . $_GET["out"] . "&" );
	print("<h1>Galleri</h1>\n");
	print("Total Images Stored: $count");
	echo $pagertop;
	$res = mysql_query("SELECT * FROM profilbilder WHERE userid = $CURUSER[id] ORDER BY added DESC $limit") or sqlerr(__FILE__, __LINE__);
	if (mysql_num_rows($res) == 0)
		print("<b>BitBucket Log is empty</b>\n");
	else {
		print("<table align='center' border='0' cellspacing='0' cellpadding='5'>\n");
		while ($arr = mysql_fetch_assoc($res)) {
			$r2 = mysql_query("SELECT username FROM users WHERE id=$arr[userid]") or sqlerr();
			$a2 = mysql_fetch_assoc($r2);
			$date = substr($arr['added'], 0, strpos($arr['added'], " "));
			$time = substr($arr['added'], strpos($arr['added'], " ") + 1);
			$name = $arr["location"];
			$fullimagepath = "/home/var/*****/*****/userpics/profilbilder/$CURUSER[username]";
			$url = str_replace(" ", "%20", htmlspecialchars("userpics/profilbilder/$CURUSER[username]/$name"));
			print("<tr>");
			print("<td><center><a href=$url><img src=$url onLoad='SetSize(this, 400)'></a></center>");
			print("Uppladdad av:  <b><a href=visaprofil.php?id=$arr[userid]>$a2[username]</a></b><br>");
                     if (get_user_class() >= UC_MODERATOR || $arr["userid"] == $CURUSER["id"])
			print(" <b><a href=?delete=$arr[picid]>[Ta bort]</a></b><br>");
			print("Datum: $date $time");
			print("</tr>");
		print("</table>");
	echo $pagerbottom;
Någon som kan hitta felet!?
Det enda som händer nu, är att sidan bara uppdateras.
Tack på förhand!
Medlem sedan mars 2003429 inlägg
Det låter ju som att du inte äns passerar is_valid_id()... testa att köra en echo innanför dess klamrar och se om du får en utskrift... om nu is_valid_id() kollar om bilden finns, varför kollar du det då igen genom att hämta den och sen kontrollera att det blev en rad?
mvh
127 ms — deklarationer (db)
117 ms — ändringar (db)
