Ingen som vet? :q
I have not failed. I´ve just found 10.000 ways that won´t work. // Thomas Edison
1 svar · 96 visningar · startad av Alpha II
Varför blir det inte rätt tid när jag spar variabeln $lmodified_mysql i databasen?
<?php
include("config.inc.php");
mysql_connect("$db_host","$db_username","$db_password") or die("Can't connect database!");
mysql_select_db("$db") or die("Can't connect database");
function showfiles() {
$Days = 30;
$sec = $Days*24*60*60;
$DateLine = Time()-$sec;
$DateLine = date("Ymdhis", $DateLine);
echo("<table border=\"0\" width=\"370\" cellpadding=\"0\" cellspacing=\"2\">");
echo("
<tr>\n
<td width=\"150\" bgcolor=\"#c0c0c0\" class=\"text2\"> <b>Namn</b></td>\n
<td bgcolor=\"#c0c0c0\" class=\"text2\"> <b>Senast uppdaterad</b></td>\n
<td width=\"50\" bgcolor=\"#c0c0c0\" class=\"text2\"> <b>Admin</b></td>\n
</tr>\n");
$drvs = mysql_query("SELECT * FROM FileList WHERE DrvLastModified > '$DateLine' ORDER BY DrvLastModified desc");
$i = 0;
while($drv = mysql_fetch_array($drvs)) {
$New = "";
$exists = "";
$lmodified = GetLastModified($drv["DrvFilename"]);
$lmodified_mysql = date("Ymdhis", $lmodified);
if($lmodified==0)
$exists = " <img src=\"img/delete.gif\" border=\"0\"><img src=\"img/delete.gif\" border=\"0\"><img src=\"img/delete.gif\" border=\"0\">";
if($lmodified_mysql > $drv["DrvLastModified"]) {
mysql_query("UPDATE FileList SET DrvLastModified='$lmodified_mysql' WHERE ID='$drv[0]'");
$New = "<img src=\"img/new.gif\" border=\"0\">";
$bgColor = (++$i & 1) ? '#F5F5F5' : '#E0E0E0';
echo("
<tr>\n
<td width=\"150\" bgcolor=\"$bgColor\" class=\"text2\"> $New<a href=\"ShowFile.php?fileid=".$drv["ID"]."\">".$drv["DrvName"]."</a>$exists</td>\n
<td bgcolor=\"$bgColor\" class=\"text2\"> ".strftime("%Y.%m.%d %H:%M",$lmodified)."</td>\n
<td bgcolor=\"$bgColor\" class=\"text2\"> <a href=\"EditFile.php?fileid=".$drv["ID"]."\"><img src=\"img/edit.gif\" border=\"0\"></a> <a href=\"DeleteFile.php?fileid=".$drv["ID"]."\"><img src=\"img/delete.gif\" border=\"0\"></a></td>\n
</tr>\n");
echo("</table>");
function GetLastModified($filename) {
if(file_exists($filename)) {
if(filetype($filename) == "dir") {
$dir = $filename;
$open_dir = opendir ($dir);
$time = 0;
while ($file = readdir($open_dir)) {
$file = basename ($file);
$file = $dir."/".$file;
if (filetype($file) != "dir") {
$mtime = filemtime ($file);
if ($mtime > $time) {
$time = $mtime;
$thatfile = $file;
closedir($open_dir);
return($time);
} else {
return(filemtime($filename));
} else return(0);
När man tar ut tiden från databsen så är det inte den tid jag det ska vara... :(
Ingen som vet? :q
