Modifiera så att script använder ftp vid uppladdning
PHP
2 svar · 391 visningar · startad av silfver
Jag har ett script som hjälper mig croppa bildfiler, 12CropImageinc.php:
<?php //
//////////////////////////                 1 2 CROP IMAGE                 //////////////////////////
//////////////////////////             (c) 2002 Roel Meurders             //////////////////////////
//////////////////////////         mail: scripts@roelmeurders.com         //////////////////////////
//////////////////////////                  version 0.2                   //////////////////////////
///// CREDITS: Most Javascript is taken from DHTMLCentral.com and is made by Thomas Brattli. ///////
///// Modified by:   Ramin Mehran @ March 2005
///// Modifications: Modified substantially to make it
/////				 compatible with Pixelpost v1.4 (Pixelpost.org) and the original php
/////				 file has been broken into seperated parts.
/////  			 Updated in release of Pixelpost 1.5 for PHP 4.4.1 and PHP 5.1.1 compatibility.
///// CVS file version: $Id: 12cropimageinc.php,v 1.11 2006/07/09 11:10:20 gajcy Exp $
// set the 12cropimage file path (in the include directory)
// You do not need to access this if not logged in - securing it
if(!isset($_SESSION["pixelpost_admin"]) || $cfgrow['password'] != $_SESSION["pixelpost_admin"] || $_GET["_SESSION"]["pixelpost_admin"] == $_SESSION["pixelpost_admin"] || $_POST["_SESSION"]["pixelpost_admin"] == $_SESSION["pixelpost_admin"]) {
	die ("Try another day!!");
  $spacer = "../includes/spacer.gif"; //Relactive path tpo spacer.gif, transparent image
  $javafile = "../includes/12cropimage.js"; //Relative path to js-file
// set global variables
global $txt, $imgW,$imgH, $imgProp, $spacer, $redirect, $javafile, $crw, $crh, $org, $res;
/* start up mysql */
mysql_error();
// if the user selected '12c' as the cropping tool
if ($_GET['x']=='12cropthumb')
	$w = $_GET['sw'];
	$h = $_GET['sh'];
	$dw = $_GET['dw'];
	$dh = $_GET['dh'];
	$file = $_GET['filename'];
if (createthumbnail_12crop($w,$h,$dw,$dh,$file))
	header("Location: index.php?view=images");
	} // end if 12cropthumb
else {echo 'Some error in 12crop: thumb is not created!';}
// get specified thumbnail width and height
    $cfgquery = mysql_query("select * from ".$pixelpost_db_prefix."config");
    $cfgrow = mysql_fetch_array($cfgquery);
    $max_width = $cfgrow['thumbwidth'];
    $max_height = $cfgrow['thumbheight'];
// renaming the variable
  $crw = $max_width;
  $crh = $max_height;
// initialize the variables with some values
  $imgH = 22;
  $imgW = 22;
  $imgProp = .4;
// save required messages
  $txt['cropimage'] = "crop";
  $txt['preview'] = "preview";
  $txt['bigger'] = "+";
  $txt['smaller'] = "-";
  $txt['closewindow'] = "close window";
  $txt['selectioninpicture'] = "The selection has to be completely on the image.";
// Functions
// prepare the cropdiv
  function setsize_cropdiv ($file){
      global $pixelpost_db_prefix , $crw,$crh,$spacer;
      // credit to codewalkers.com - there is 90% a tutorial there
      define(IMAGE_BASE, "../images");
      $image_path = IMAGE_BASE . "/$file";
      $img = null;
      $ext_exp = explode('.', $image_path);
      $ext_end = end($ext_exp);
      $ext = strtolower($ext_end);
      if ($ext == 'jpg' || $ext == 'jpeg') {
        $img = @imagecreatefromjpeg($image_path);
          } else if ($ext == 'png') {
          $img = @imagecreatefrompng($image_path);
          } else if ($ext == 'gif') {
          $img = @imagecreatefromgif($image_path);
      if($img) {
      	  $rtrn = true;
          $imgW = imagesx($img);
          $imgH = imagesy($img);
          $divsize = $imgH+50;
          $imgProp = .8* min($imgW/$max_width, $imgH/$max_height);
		  $imgProp1 = $crw*$imgProp;
		  $imgProp2 = $crh*$imgProp;
    echo "<style type='text/css'>#cropdiv {position:absolute;width:$imgProp1".px.";height:$imgProp2".px.";z-index:2;background-image:url(".$spacer."); }
		      #editthumbnail{position:relative;height:$divsize".px.";visibility: hidden;}
		       </style>";
       } else {
			  $rtrn = false;}
        imagedestroy($img);
        return $rtrn;
 // special createthumbnail which uses 12cropimage
  function createthumbnail_12crop($w,$h,$dw,$dh,$file)
    global $pixelpost_db_prefix;
      $tmp_img = imagecreatetruecolor($max_width,$max_height);
      $img = null;
      //$ext = strtolower(end(explode('.', $image_path)));
      if($img) {
          $width = imagesx($img);
          $height = imagesy($img);
		// gd 2.0.1 or later: imagecopyresampled
		// gd less than 2.0: imagecopyresized
       if(function_exists(imagecopyresampled)) {
                  imagecopyresampled($tmp_img, $img, 0,0,$w,$h,$max_width,$max_height,$dw,$dh);
                  } else {
                  imagecopyresized($tmp_img, $img, 0,0,$w,$h,$max_width ,$max_height,$dw,$dh);
           imagedestroy($img);
// now save the thumbnail
		 	touch("../thumbnails/thumb_$file");
        	imagejpeg($tmp_img, "../thumbnails/thumb_$file",$cfgrow['compression']);
  		     $thumbimage = "../thumbnails/thumb_$file";
      		 chmod($thumbimage,0644);
       		 imagedestroy($tmp_img);
           return true;
       }// if $img
// if you are here, something's wrong
  	return false;
/// End of functions
Synd att man inte kan se rader i [ php ]-taggen, men på rad 164 (nästan längst ner) så hittar man dessa rader:
           return true;
Vad jag skulle behöva hjälp med är att göra så att det här scriptet använder FTP för att lägga upp filerna i stället för... vad den nu använder.
Är detta möjligt? Skulle vara otroligt jättetacksam för hjälp! :bire
Medlem sedan mars 2005232 inlägg
Den sparar väl bilderna i en mapp på din ftp? Eller vill du kunna ansluta till en annan ftp med anv och lösen och spara bilderna där istället?
Ja, den sparar bilderna på ftp:n så klart, men den använder inte ftp-funktionen för att ladda tillbaka bilderna - vilket jag vill att den ska göra. För när den inte gör det så är det inte jag som blir ägare till bilderna - vilket ställer till en massa problem. :l
Förstår ni vad jag menar? :)
125 ms — deklarationer (db)
130 ms — ändringar (db)
