php.ini
2 svar · 199 visningar · startad av toja
tojaMedlem sedan mars 2001217 inlägg
Tjena!
Jag har ett problem med mina sessioner... jag får dem inte att fungera över huvudtaget... jag kör IIS på Win2000. Jag undrar om det kan vara nått med php.ini inställningarna...
Så här ser det ut i php.ini:
[Session]
session.save_handler = files ; handler used to store/retrieve data
session.save_path = /tmp ; argument passed to save_handler
; in the case of files, this is the
; path where data files are stored
session.use_coookies = 1 ; whether to use coookies
session.name = PHPSESSID
; name of the session
; is used as coookie name
session.auto_start = 0 ; initialize session on request startup
session.coookie_lifetime = 0 ; lifetime in seconds of coookie
; or if 0, until browser is restarted
session.coookie_path = / ; the path the coookie is valid for
session.coookie_domain = ; the domain the coookie is valid for
session.serialize_handler = php ; handler used to serialize data
; php is the standard serializer of PHP
session.gc_probability = 1 ; percentual probability that the
; 'garbage collection' process is started
; on every session initialization
session.gc_maxlifetime = 1440 ; after this number of seconds, stored
; data will be seen as 'garbage' and
; cleaned up by the gc process
session.referer_check = ; check HTTP Referer to invalidate
; externally stored URLs containing ids
session.entropy_length = 0 ; how many bytes to read from the file
session.entropy_file = ; specified here to create the session id
; session.entropy_length = 16
; session.entropy_file = /dev/urandom
session.cache_limiter = nocache ; set to {nocache,private,public} to
; determine HTTP caching aspects
session.cache_expire = 180 ; document expires after n minutes
session.use_trans_sid = 1 ; use transient sid support if enabled
; by compiling with --enable-trans-sid
url_rewriter.tags = "a=href,area=href,frame=src,input=src,form=fakeentry"
OBS! Skriver Coookie med tre "o" för att men tydligen inte får skriva coookie med två i detta forum!
Är något fel här...???
Tacksam för svar...
/Toja phpProgrammer
BatboyMedlem sedan jan. 2000888 inlägg
Har du en /tmp mapp?
Om inte, ändra.
session.save_path = c:/php/tmp
eller nåt..
cookie?
/j
R6
ok...ska testa det...
/Toja phpProgrammer
Genererad på 379 ms · cache AV · v20260730165559-full.f96bc7eb
