i if-satsen som innehåller recordset3, om den blir "sann" skicka då vidare till en annan sida med location header..skicka också med nödvändiga variablar
*EDIT
Läste lite fel, trodde du ville skicka record3 till annan sida
Jag vill inte att Recordset3 visas samtidigt som Recordset2 på samma sida.
Tacksam för tips!
Mvh Acke
<?php require_once('../Connections/xxx.php'); ?>
<?php
if (!function_exists("GetSQLValueString")) {
function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
$theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
switch ($theType) {
case "text":
$theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
break;
case "long":
case "int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
$theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
break;
return $theValue;
$maxRows_Recordset1 = 10;
$pageNum_Recordset1 = 0;
if (isset($_GET['pageNum_Recordset1'])) {
$pageNum_Recordset1 = $_GET['pageNum_Recordset1'];
$startRow_Recordset1 = $pageNum_Recordset1 * $maxRows_Recordset1;
mysql_select_db($database_xxx, $xxx);
$query_Recordset1 = "SELECT namn, kommun FROM boende";
$query_limit_Recordset1 = sprintf("%s LIMIT %d, %d", $query_Recordset1, $startRow_Recordset1, $maxRows_Recordset1);
$Recordset1 = mysql_query($query_limit_Recordset1, $xxx) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
if (isset($_GET['totalRows_Recordset1'])) {
$totalRows_Recordset1 = $_GET['totalRows_Recordset1'];
} else {
$all_Recordset1 = mysql_query($query_Recordset1);
$totalRows_Recordset1 = mysql_num_rows($all_Recordset1);
$totalPages_Recordset1 = ceil($totalRows_Recordset1/$maxRows_Recordset1)-1;
$maxRows_Recordset2 = 10;
$pageNum_Recordset2 = 0;
if (isset($_GET['pageNum_Recordset2'])) {
$pageNum_Recordset2 = $_GET['pageNum_Recordset2'];
$startRow_Recordset2 = $pageNum_Recordset2 * $maxRows_Recordset2;
$colname_Recordset2 = "-1";
if (isset($_GET['recordID'])) {
$colname_Recordset2 = (get_magic_quotes_gpc()) ? $_GET['recordID'] : addslashes($_GET['recordID']);
$query_Recordset2 = sprintf("SELECT DISTINCT namn, kommun FROM boende WHERE kommun = %s ORDER BY kommun ASC", GetSQLValueString($colname_Recordset2, "text"));
$query_limit_Recordset2 = sprintf("%s LIMIT %d, %d", $query_Recordset2, $startRow_Recordset2, $maxRows_Recordset2);
$Recordset2 = mysql_query($query_limit_Recordset2, $xxx) or die(mysql_error());
$row_Recordset2 = mysql_fetch_assoc($Recordset2);
if (isset($_GET['totalRows_Recordset2'])) {
$totalRows_Recordset2 = $_GET['totalRows_Recordset2'];
} else {
$all_Recordset2 = mysql_query($query_Recordset2);
$totalRows_Recordset2 = mysql_num_rows($all_Recordset2);
$totalPages_Recordset2 = ceil($totalRows_Recordset2/$maxRows_Recordset2)-1;
$maxRows_Recordset3 = 10;
$pageNum_Recordset3 = 0;
if (isset($_GET['pageNum_Recordset3'])) {
$pageNum_Recordset3 = $_GET['pageNum_Recordset3'];
$startRow_Recordset3 = $pageNum_Recordset3 * $maxRows_Recordset3;
$query_Recordset3 = "SELECT namn, kategori, kommun FROM boende ORDER BY kommun ASC";
$query_limit_Recordset3 = sprintf("%s LIMIT %d, %d", $query_Recordset3, $startRow_Recordset3, $maxRows_Recordset3);
$Recordset3 = mysql_query($query_limit_Recordset3, $xxx) or die(mysql_error());
$row_Recordset3 = mysql_fetch_assoc($Recordset3);
if (isset($_GET['totalRows_Recordset3'])) {
$totalRows_Recordset3 = $_GET['totalRows_Recordset3'];
} else {
$all_Recordset3 = mysql_query($query_Recordset3);
$totalRows_Recordset3 = mysql_num_rows($all_Recordset3);
$totalPages_Recordset3 = ceil($totalRows_Recordset3/$maxRows_Recordset3)-1;
:q
