Foreachfelmeddelande?
PHP
2 svar · 298 visningar · startad av eklof00
Medlem sedan jan. 200737 inlägg
Är det någon som kan hjälpa mig och se vad som är fel. Antar att jag har fel värden på rad 17.
Warning: Invalid argument supplied for foreach() in C:\wamp\www\spel.php on line 17
Warning: Cannot modify header information - headers already sent by (output started at C:\wamp\www\spel.php:17) in C:\wamp\www\spel.php on line 22
<?php
session_start(); // Alltid överst på sidan
include "conn.php"; // Databasanslutningen
// Kolla om inloggad = sessionen satt
if (!isset($_SESSION['sess_date'])){
  header("Location: test.php");
  exit;
if (!isset($_SESSION['sess_user_id'])){
  header("Location: index.php");
  exit;
if (isset($_POST['submit'])) {
    $i = 0;
foreach($_POST['tips'] as $tips) {  //RAD 17
        $sql = "INSERT INTO spel_allsv2007 (user_id, match_id, tips) VALUES('{$_SESSION['sess_user_id']}','{$_POST['match_id'][$i]}','{$_POST['tips_'.$_POST['match_id'][$i]]}'))";
        mysql_query($sql) or die("SQL: $sql <br>".mysql_error());
        $i++;
     header("Location: user_tips.php");
     exit;
<form action="spel.php" method="post" name="submit">
<?PHP
$sql = "SELECT * FROM allsv2007 WHERE date > CURRENT_TIMESTAMP() AND date = ' {$_SESSION['sess_date']} '" or die(mysql_error());
$result = mysql_query($sql);
   while ($row = mysql_fetch_assoc($result)) {
$date[$row['date']][] = array($row['match_id'], $row['matcher']);
if (isset($date) && !empty($date)) {
      echo '<table>';
      foreach ($date as $day => $value){
          echo '<tr>';
         echo '<td></td>';
         echo '<td>' . '<b>' . $day. '</b>' . '</td>';
         echo '<td align="center"><b>1</b></td>';
         echo '<td align="center"><b>X</b></td>';
         echo '<td align="center"><b>2</b></td>';
      echo '</tr>';
        foreach ($value as $game)
        echo '<tr>';
        echo '<td align ="right">'. $game[0].'.</td>';
         echo '<td>'. $game[1].'</td>';
         echo '<td><input type="radio" value="1" name="tips_'.$game[0].'"></td>
                 <td><input type="radio" value="X" name="tips_'.$game[0].'"></td>
                 <td><input type="radio" value="2" name="tips_'.$game[0].'"><input type="hidden" name="match_id[]" value="'.$game[0].'"></td>';
         echo '</tr>';
echo '</table>';
}else{
echo 'Du kan inte spela på denna match, Spelstopp har inträtt!';
<input type="submit" name="submit" value="Skicka">
Medlem sedan maj 2005562 inlägg
Troligtvis innehåller inte $_POST['tips'] en array.
Testa använda var_dump($_POST); och testa så den innehåller vad du förväntar dig.
Så här blev det efter mycket om och men...
foreach($_POST['match_id'] as $match) {
267 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
131 ms — deklarationer (db)
122 ms — ändringar (db)
