Vad gör jag för fel med scriptet?
PHP
1 svar · 419 visningar · startad av xtreme
Medlem sedan juli 20002 056 inlägg
Har laddat ner http://www.says-it.com/faq.php#general15
http://www.churchsigngenerator.com/source.phps
Har även laddat ner bilderna
http://www.churchsigngenerator.com/images/basesign_example.jpg
http://www.churchsigngenerator.com/images/chars_example.png
samt tagit bort "exempel i bilderna"
Ena bilden är i .jpg och jag har provat att göra om den till .png men får ändå inte det att funka.
Får felen:
Warning: imagecreatefrompng() [function.imagecreatefrompng]: 'basesign.jpg' is not a valid PNG file in /home/bordell/public_html/test/index.php on line 283
Warning: imagesx(): supplied argument is not a valid Image resource in /home/bordell/public_html/test/index.php on line 287
Warning: imagesy(): supplied argument is not a valid Image resource in /home/bordell/public_html/test/index.php on line 288
Warning: imagecreatetruecolor() [function.imagecreatetruecolor]: Invalid image dimensions in /home/bordell/public_html/test/index.php on line 292
Warning: imagecopy(): supplied argument is not a valid Image resource in /home/bordell/public_html/test/index.php on line 296
Warning: Cannot modify header information - headers already sent by (output started at /home/bordell/public_html/test/index.php:1) in /home/bordell/public_html/test/index.php on line 374
Warning: Cannot modify header information - headers already sent by (output started at /home/bordell/public_html/test/index.php:1) in /home/bordell/public_html/test/index.php on line 375
Warning: imagejpeg(): supplied argument is not a valid Image resource in /home/bordell/public_html/test/index.php on line 381
Warning: imagedestroy(): supplied argument is not a valid Image resource in /home/bordell/public_html/test/index.php on line 384
Warning: imagedestroy(): supplied argument is not a valid Image resource in /home/bordell/public_html/test/index.php on line 386
Lite tips på hur jag ska göra? ;)
Medlem sedan juli 2006461 inlägg
Rad 274 får du byta ut till följande:
$basesign_img = imagecreatefrompng("basesign.png");
261 ms totalt · 4 externa anrop · v20260731065814-full.1dc6f849
125 ms — deklarationer (db)
126 ms — ändringar (db)
