Kalenderproblem
3 svar · 328 visningar · startad av Madmartigan
MadmartiganMedlem sedan sep. 200315 inlägg
Jag har hittat en kod till en enkel gratis kalender i php. När jag försöker köra koden på min sida blir det bar blankt. Den skrivs inte ut alls. Vad är fel?
Kod:
<?php
function generate_calendar($year, $month, $days = array(), $day_name_length = 3, $month_href = NULL, $first_day = 1, $pn = array()){
$first_of_month = gmmktime(0, 0, 0, 1, 1, 1998);
$day_names = array(); #generate all the day names according to the current locale
for($n=0,$t=(3+$first_day)\*86400; $n\<7; $n++,$t+=86400) #January 4, 1970 was a Sunday
    $day_names\[$n\] = ucfirst(gmstrftime('%A',$t)); #%A means full textual day name
list($month, $year, $month_name, $weekday) = explode(',',gmstrftime('%m,%Y,%B,%w',$first_of_month));
$weekday = ($weekday + 7 - $first_day) % 7; #adjust for $first_day
$title   = htmlentities(ucfirst($month_name)).'&nbsp;'.$year;  #note that some locales don't capitalize month and day names
\#Begin calendar. Uses a real \<caption\>. See http://diveintomark.org/archives/2002/07/03
@list($p, $pl) = each($pn); @list($n, $nl) = each($pn); #previous and next links, if applicable
if($p) $p = '\<span class="calendar-prev"\>'.($pl ? '\<a href="'.htmlspecialchars($pl).'"\>'.$p.'\</a\>' : $p).'\</span\>&nbsp;';
if($n) $n = '&nbsp;\<span class="calendar-next"\>'.($nl ? '\<a href="'.htmlspecialchars($nl).'"\>'.$n.'\</a\>' : $n).'\</span\>';
$calendar = '\<table class="calendar"\>'."\\n".
    '\<caption class="calendar-month"\>'.$p.($month_href ? '\<a href="'.htmlspecialchars($month_href).'"\>'.$title.'\</a\>' : $title).$n."\</caption\>\\n\<tr\>";
if($day_name_length){ #if the day names should be shown ($day_name_length \> 0)
    \#if day_name_length is \>3, the full name of the day will be printed
    foreach($day_names as $d)
        $calendar .= '\<th abbr="'.htmlentities($d).'"\>'.htmlentities($day_name_length \< 4 ? substr($d,0,$day_name_length) : $d).'\</th\>';
    $calendar .= "\</tr\>\\n\<tr\>";
if($weekday \> 0) $calendar .= '\<td colspan="'.$weekday.'"\>&nbsp;\</td\>'; #initial 'empty' days
for($day=1,$days_in_month=gmdate('t',$first_of_month); $day\<=$days_in_month; $day++,$weekday++){
    if($weekday == 7){
        $weekday   = 0; #start a new week
    if(isset($days\[$day\]) and is_array($days\[$day\])){
        @list($link, $classes, $content) = $days\[$day\];
        if(is_null($content))  $content  = $day;
        $calendar .= '\<td'.($classes ? ' class="'.htmlspecialchars($classes).'"\>' : '\>').
            ($link ? '\<a href="'.htmlspecialchars($link).'"\>'.$content.'\</a\>' : $content).'\</td\>';
    else $calendar .= "\<td\>$day\</td\>";
if($weekday != 7) $calendar .= '\<td colspan="'.(7-$weekday).'"\>&nbsp;\</td\>'; #remaining "empty" days
return $calendar."\</tr\>\\n\</table\>\\n";
Jag kan dessvärre inte hjälpa dig med ditt problem, men snälla, använd [php]-taggar runt koden du postar så går den att läsa.
mvh
PeddaMedlem sedan juni 20004 880 inlägg
Anropar du funktionen rätt där du ska visa den?
GislavedMedlem sedan nov. 20041 480 inlägg
Du måste anropa funktionen också.
<? echo generate_calendar("2006", "11", "09"); ?>
