Jag har ställt denna fråga på andra forum, men utan att få svar. Ställer mitt hopp till er här.
Det är så att jag laddat ner ett mailscript och jag skulle vilja lägga till flera fält än de som finns. Fälten lyckas jag med, men innehållet i fälten kommer inte med i mailet. Här är scriptet:
function get_ext($key) {
$key=strtolower(substr(strrchr($key, "."), 1));
// Cause there the same right?
$key=str_replace("jpeg","jpg",$key);
return $key;
function phattach($file,$name) {
global $boundary;
$fp=@fopen($file,"r");
$str=@fread($fp, filesize($file));
$str=@chunk_split(base64_encode($str));
$message="--".$boundary."\n";
$message.="Content-Type: application/octet-stream; name=\"".$name."\"\n";
//$message.="Content-disposition: attachment\n"; Thanks goes to someone named Chris (I think, it was awhile ago) for his fix below!
$message.="Content-disposition: attachment; filename=\"".$name."\"\n";
$message.="Content-Transfer-Encoding: base64\n";
$message.="\n";
$message.="$str\n";
$message.="\n";
return $message;
//Little bit of security from people forging headers. People are mean sometimes :(
function clean($key) {
$key=str_replace("\r", "", $key);
$key=str_replace("\n", "", $key);
$find=array(
"/bcc\:/i",
"/Content\-Type\:/i",
"/Mime\-Type\:/i",
"/cc\:/i",
"/to\:/i"
$key=preg_replace($find,"",$key);
return $key;
// Safe for register_globals=on =)
$error="";
$types="";
$sent_mail=false;
// Do some loopy stuff for the valid file types so people can see what types are valid before they try and upload invalid ones.
$ext_count=count($allowtypes);
$i=0;
foreach($allowtypes AS $extension) {
//Gets rid of the last comma
If($i <= $ext_count-2) {
$types .="*.".$extension.", ";
} Else {
$types .="*.".$extension;
$i++;
unset($i,$ext_count); // why not
// If they post the form start the mailin'!
If($_POST['submit']==true) {
extract($_POST, EXTR_SKIP);
// Check the form for errors
If(trim($yourname)=="") {
$error.="You did not enter your name!<br />";
If(trim($youremail)=="") {
$error.="You did not enter your email!<br />";
} Elseif(!eregi("^([a-z0-9_]|\\-|\\.)+@(([a-z0-9_]|\\-)+\\.)+[a-z]{2,4}\$",$youremail)) {
$error.="Invalid email address.<br />";
If(trim($emailsubject)=="") {
$emailsubject=$defaultsubject;
If(trim($yourmessage)=="") {
$error.="You did not enter a message!<br />";
// Verify Attchment info
If($allowattach > 0) {
//Loopish
For($i=0; $i <= $allowattach-1; $i++) {
If($_FILES['attachment']['name'][$i]) {
$ext=get_ext($_FILES['attachment']['name'][$i]);
$size=$_FILES['attachment']['size'][$i];
$max_bytes=$max_file_size*1024;
//Check if the file type uploaded is a valid file type.
If(!in_array($ext, $allowtypes)) {
$error.= "Invalid extension for your file: ".$_FILES['attachment']['name'][$i].", only ".$types." are allowed.<br />";
//Check the size of each file
} Elseif($size > $max_bytes) {
$error.= "Your file: ".$_FILES['attachment']['name'][$i]." is to big. Max file size is ".$max_file_size."kb.<br />";
} // If Files
} // For
//Tally the size of all the files uploaded, check if it's over the ammount.
$total_size=array_sum($_FILES['attachment']['size']);
$max_file_total_bytes=$max_file_total*1024;
If($total_size > $max_file_total_bytes) {
$error.="The max size allowed for all your files is ".$max_file_total."kb<br />";
} // If Allowattach
If($error) {
$display_message=$error;
} Else {
If($use_subject_drop AND is_array($subjects) AND is_array($emails)) {
$subject_count=count($subjects);
$email_count=count($emails);
If($subject_count==$email_count) {
$myemail=$emails[$emailsubject];
$emailsubject=$subjects[$emailsubject];
$boundary=md5(uniqid(time()));
$yourname=clean($yourname);
$yourmessage=clean($yourmessage);
$youremail=clean($youremail);
//Headers
$headers="From: ".$yourname." <".$youremail.">\n";
$headers.="Reply-To: ".$yourname." <".$youremail.">\n";
$headers.="MIME-Version: 1.0\n";
$headers.="Content-Type: multipart/mixed; boundary=\"".$boundary."\"\n";
$headers.="X-Sender: ".$_SERVER['REMOTE_ADDR']."\n";
$headers.="X-Mailer: PHP/".phpversion()."\n";
$headers.="X-Priority: ".$priority."\n";
$headers.="Return-Path: <".$youremail.">\n";
$headers.="This is a multi-part message in MIME format.\n";
//Message
$message = "--".$boundary."\n";
$message.="Content-Type: text/plain; charset=\"iso-8859-1\"\n";
$message.="Content-Transfer-Encoding: quoted-printable\n";
$message.="\n";
$message.="$yourmessage";
$message.="\n";
//Lets attach to something! =)
$message.=phattach($_FILES['attachment']['tmp_name'][$i],$_FILES['attachment']['name'][$i]);
} //For
} // If
// End the message
$message.="--".$boundary."--\n";
// Send the completed message
If(!mail($myemail,$emailsubject,$message,$headers)) {
Exit("An error has occured, please report this to the website administrator.\n");
} Else {
$sent_mail=true;
} // Else
} // $_POST
var error="";
e_regex = /^\w+([\.-]?\w+)*@\w+([\.-]?\w+)*(\.\w{2,})+$/;
function Checkit(theform) {
if(theform.yourname.value=="") {
error+="You did not enter your name\n";
if(theform.youremail.value=="") {
error+="You did not enter your email\n";
} else if(!e_regex.test(theform.youremail.value)) {
error+="Invalid email address\n";
if(theform.yourmessage.value=="") {
error+="You did not enter your message\n";
if(error) {
alert('**The form returned the following errors:**\n\n' + error);
error="";
return false;
} else {
return true;
<body>
<?If($display_message) {?>
<div align="center" class="error_message"><b><?=$display_message;?></b></div>
<br />
<?If($sent_mail!=true) {?>
<form method="post" action="<?=$_SERVER['PHP_SELF'];?>" enctype="multipart/form-data" name="phmailer" onsubmit="return Checkit(this);">
<table align="center" class="table">
<tr>
<td colspan="2" class="table_header" width="100%"><?=$websitename;?></td>
</tr>
<?If($allowattach > 0) {?>
<tr>
<td width="100%" class="attach_info" colspan="2">
<b>Valid Attachment Types:</b> <?=$types?><br />
<b>Max size per file:</b> <?=$max_file_size?>kb.<br />
<b>Max combined file size:</b> <?=$max_file_total?>kb.
</td>
</tr>
<tr>
<td width="30%" class="table_body">Your Name:</td>
<td width="70%" class="table_body"><input name="yourname" type="text" size="30" value="<?=stripslashes(htmlspecialchars($yourname));?>" /><span class="error_message">*</span></td>
</tr>
<tr>
<td width="30%" class="table_body">Your Email:</td>
<td width="70%" class="table_body"><input name="youremail" type="text" size="30" value="<?=stripslashes(htmlspecialchars($youremail));?>" /><span class="error_message">*</span></td>
</tr>
<tr>
<td width="30%" class="table_body">Subject:</td>
<?If($use_subject_drop AND is_array($subjects)) {?>
<select name="emailsubject" size="1">
<?while(list($key,$val)=each($subjects)) {?>
<option value="<?=intval($key);?>"><?=htmlspecialchars(stripslashes($val));?></option>
</select>
<?} Else {?>
<input name="emailsubject" type="text" size="30" value="<?=stripslashes(htmlspecialchars($emailsubject));?>" />
</td>
</tr>
<?For($i=1;$i <= $allowattach; $i++) {?>
<tr>
<td width="30%" class="table_body">Attach File:</td>
<td width="70%" class="table_body"><input name="attachment[]" type="file" size="30" /></td>
</tr>
<tr>
<td colspan="2" width="100%" class="table_body">Your Message:<span class="error_message">*</span><br />
<div align="center">
<textarea name="yourmessage" rows="8" cols="60"><?=stripslashes(htmlspecialchars($yourmessage));?></textarea>
</td>
</tr>
<tr>
<td colspan="2" width="100%" class="table_footer">
<input type="hidden" name="submit" value="true" />
<input type="submit" value="<?=$submitvalue;?>" />
<input type="reset" value="<?=$resetvalue;?>" />
</td>
</tr>
</table>
<?} Else {?>
<div align="center" class="thanks_message"><?=$thanksmessage;?></div>
<br />
<br />
Förstår inte riktigt frågan, vill du ha ytterligare tre inputs som också skall komma med i mailet? Just nu finns dom ju inte på sidan som du angav. Annar lägg till detta i formuläret:
Stort tack Vic, det var precis det jag menade. :) Skall prova det när jag kommer hem i eftermiddag. (De nya fälten var inte där då jag la upp ett orört script för att inte röra till det i onödan.)
