Först vill jag bara ursäkta mig för att mitt inlägg blir modell större, men det verkar vara enda sättet för mig att få detta löst. Jag får inte mina sessions och cookies att fungera. Jag VET att min kod fungerar, men det verkar som inställningarna lokalt verkar vara lite tokiga.
Om nån av er orkar skumma igenom mina inställningar i PHP.ini är korrekt så blir jag mkt glad. Obs. Save-pathen fungerar.
[Session]
session.save_handler = files ; handler used to store/retrieve data
session.save_path = c:/apache/htdocs/tmp ; argument passed to save_handler
; in the case of files, this is the
; path where data files are stored
session.use_cookies = 1 ; whether to use cookies
session.name = PHPSESSID
; name of the session
; is used as cookie name
session.auto_start = 0 ; initialize session on request startup
session.cookie_lifetime = 1800 ; lifetime in seconds of cookie
; or if 0, until browser is restarted
session.cookie_path = / ; the path the cookie is valid for
session.cookie_domain = 127.0.0.1 ; the domain the cookie is valid for
session.serialize_handler = php ; handler used to serialize data
; php is the standard serializer of PHP
session.gc_probability = 1 ; percentual probability that the
; 'garbage collection' process is started
; on every session initialization
session.gc_maxlifetime = 1440 ; after this number of seconds, stored
; data will be seen as 'garbage' and
; cleaned up by the gc process
session.referer_check = ; check HTTP Referer to invalidate
; externally stored URLs containing ids
session.entropy_length = 0 ; how many bytes to read from the file
session.entropy_file = ; specified here to create the session id
; session.entropy_length = 16
; session.entropy_file = /dev/urandom
session.cache_limiter = nocache ; set to {nocache,private,public} to
; determine HTTP caching aspects
session.cache_expire = 180 ; document expires after n minutes
session.use_trans_sid = 1 ; use transient sid support if enabled
; by compiling with --enable-trans-sid
url_rewriter.tags = "a=href,area=href,frame=src,input=src,form=fakeentry"
DinDator.nu
