Har ett script för att zippa flera filer samtidigt, det går dock inte att zippa fler än en fil åt gången, hur kan det komma sig=?
<?php
// Class definition found at http://www.zend.com/zend/spotlight/creating-zip-files3.php
// Some alterations to the original posted code were made in order to get everything working properly
// See example usage at the bottom of this page
class zipfile
var $datasec = array();
var $ctrl_dir = array();
var $eof_ctrl_dir = "\x50\x4b\x05\x06\x00\x00\x00\x00";
var $old_offset = 0;
function add_dir($name) {
$name = str_replace("\\", "/", $name);
$fr = "\x50\x4b\x03\x04";
$fr .= "\x0a\x00";
$fr .= "\x00\x00";
$fr .= "\x00\x00";
$fr .= "\x00\x00\x00\x00";
$fr .= pack("V",0);
$fr .= pack("V",0);
$fr .= pack("V",0);
$fr .= pack("v", strlen($name) );
$fr .= pack("v", 0 );
$fr .= $name;
$fr .= pack("V", 0);
$this -> datasec[] = $fr;
$new_offset = strlen(implode("", $this->datasec));
$cdrec = "\x50\x4b\x01\x02";
$cdrec .="\x00\x00";
$cdrec .="\x0a\x00";
$cdrec .="\x00\x00\x00\x00";
$cdrec .= pack("V",0);
$cdrec .= pack("v", strlen($name) );
$cdrec .= pack("v", 0 );
$ext = "\x00\x00\x10\x00";
$ext = "\xff\xff\xff\xff";
$cdrec .= pack("V", 16 );
$cdrec .= pack("V", $this -> old_offset );
$cdrec .= $name;
$this -> ctrl_dir[] = $cdrec;
$this -> old_offset = $new_offset;
return;
function add_file($data, $name) {
$fp = fopen($data,"r");
$data = fread($fp,filesize($data));
fclose($fp);
$unc_len = strlen($data);
$crc = crc32($data);
$zdata = gzcompress($data);
$zdata = substr ($zdata, 2, -4);
$c_len = strlen($zdata);
$fr .= "\x14\x00";
$fr .= "\x00\x00";
$fr .= "\x08\x00";
$fr .= pack("V",$crc);
$fr .= pack("V",$c_len);
$fr .= pack("V",$unc_len);
$fr .= $name;
$fr .= $zdata;
$cdrec .="\x14\x00";
$cdrec .="\x08\x00";
$cdrec .= pack("V",$crc);
$cdrec .= pack("V",$c_len);
$cdrec .= pack("V",$unc_len);
$cdrec .= pack("V", 32 );
$cdrec .= $name;
function file() {
$data = implode("", $this -> datasec);
$ctrldir = implode("", $this -> ctrl_dir);
return
$data .
$ctrldir .
$this -> eof_ctrl_dir .
pack("v", sizeof($this -> ctrl_dir)) .
pack("V", strlen($ctrldir)) .
pack("V", strlen($data)) .
"\x00\x00";
require ("../../../../../webadmin/admin/connect_to_db.php");
// Skapa slumpmässigt kod som kommer vara kärnarn i hela utbytet mellan kund och znap
$random = "";
$antal = 5;
for ($n = 0; $n <= $antal; $n++)
$random .= chr(rand(65,90));
// Zippa låtarna
$zipTest = new zipfile();
$zipTest->add_dir("$random/");
$sess_result = mysql_query("SELECT * FROM mp3");
while($row = mysql_fetch_array($sess_result))
if($v1 == $row['id'])
$zipTest->add_file("../".$row['namn']."", "".$row['namn']."");
if($v2 == $row['id'])
$zipTest->add_file("../".$row['namn']."", "../".$row['namn']."");
$filename = "$random.zip";
$fd = fopen ($filename, "wb");
$out = fwrite ($fd, $zipTest -> file());
fclose ($fd);
echo "<a href=\"" .$filename. "\">Click here to download the new zip file" .$random.".</a>";
