stevenetMedlem sedan juni 20001 251 inlägg ... är var jag har problem med.
Någon som kan lösa det?
include("installningar.php");
$tid=time();
$vecka=get_week_number($tid);
$dag=date("w");
if ($vecka=="1") {
$tabort=51;
if ($vecka=="2") {
$tabort=52;
$tid=date("H:i");
if ($vecka=="52") {
$vecka=1;
else {
$vecka++;
if ($dag=="0") {
if ($tid=="12:00") {
$result = mysql_query("SELECT * FROM vecka WHERE vecka = '$vecka'");
while ($rowdataaa = mysql_fetch_row($result))
mysql_query("INSERT INTO vecka (sajtid, anvandarnamn, vecka, man, tis, ons, tor, fre, lor, son) VALUES ('$rowdataaa[0]','$rowdataaa[1]','$vecka','0','0','0','0','0','0','0'");
mysql_query("DELETE FROM vecka where id = '$rowdataaa[0]'");
next;
$resultaaa = mysql_query("SELECT * FROM bevaka");
while ($rowdata = mysql_fetch_row($resultaaa)) {
$epost = mysql_fetch_row(mysql_query("select * from medlemmar where anvandarnamn = $rowdata[1]"));
$kat1 = mysql_fetch_row(mysql_query("select * from kat where id = $rowdata[2]"));
$kat2 = mysql_fetch_row(mysql_query("select * from kat where id = $rowdata[3]"));
$kat3 = mysql_fetch_row(mysql_query("select * from kat where id = $rowdata[4]"));
$kat4 = mysql_fetch_row(mysql_query("select * from kat where id = $rowdata[5]"));
$kat5 = mysql_fetch_row(mysql_query("select * from kat where id = $rowdata[6]"));
if ($rowdata[7]) {
$resulta1 = mysql_query("SELECT * FROM beskrivning LIKE '%$rowdata[7]%' OR titel LIKE '%$rowdata[7]%' AND kat = '$rowdata[2]' ORDER BY roster DESC");
else {
$resulta1 = mysql_query("SELECT * FROM sajter WHERE kat = '$rowdata[2]' ORDER BY roster DESC");
while ($rowdata1 = mysql_fetch_row($resulta1)) {
$i1=0;
$forsta="";
if ($rowdata1[2]=>$rowdata[8]) {
$i1++;
$forsta .= "$i1. $rowdata1[5] - $rowdata1[4]\n";
if ($i1=="3") { break; }
if ($rowdata[7]) {
$resulta1 = mysql_query("SELECT * FROM sajter WHERE beskrivning LIKE '%$rowdata[7]%' OR titel LIKE '%$rowdata[7]%' AND kat = '$rowdata[3]' ORDER BY roster DESC");
else {
$resulta1 = mysql_query("SELECT * FROM sajter WHERE kat = '$rowdata[3]' ORDER BY roster DESC");
$i1=0;
$andra="";
if ($rowdata1[2]=>$rowdata[8)) {
$i1++;
$andra .= "$i1. $rowdata1[5] - $rowdata1[4]\n";
if ($rowdata[7]) {
$resulta1 = mysql_query("SELECT * FROM sajter WHERE beskrivning LIKE '%$rowdata[7]%' OR titel LIKE '%$rowdata[7]%' AND kat = '$rowdata[4]' ORDER BY roster DESC");
else {
$resulta1 = mysql_query("SELECT * FROM sajter WHERE kat = '$rowdata[4]' ORDER BY roster DESC");
$i1=0;
$tredje="";
$i1++;
$tredje= "$i1. $rowdata1[5] - $rowdata1[4]\n";
if ($rowdata[7]) {
$resulta1 = mysql_query("SELECT * FROM sajter WHERE beskrivning LIKE '%$rowdata[7]%' OR titel LIKE '%$rowdata[7]%' AND kat = '$rowdata[5]' ORDER BY roster DESC");
else {
$resulta1 = mysql_query("SELECT * FROM sajter WHERE kat = '$rowdata[5]' ORDER BY roster DESC");
$i1=0;
$fjarde="";
$i1++;
$fjarde .= "$i1. $rowdata1[5] - $rowdata1[4]\n";
if ($rowdata[7]) {
$resulta1 = mysql_query("SELECT * FROM sajter WHERE beskrivning LIKE '%$rowdata[7]%' OR titel LIKE '%$rowdata[7]%' AND kat = '$rowdata[6]' ORDER BY roster DESC");
else {
$resulta1 = mysql_query("SELECT * FROM sajter WHERE kat = '$rowdata[6]' ORDER BY roster DESC");
$i1=0;
$femte="";
$i1++;
$femte .= "$i1. $rowdata1[5] - $rowdata1[4]\n";
$meddelande="Hej!\n$kat1\n$forsta\n\n$kat2\n$andra\n\n$kat3\n$tredje\n\n$kat4\n$fjarde\n\n$kat5\n$femte\n\nMed vänliga hälsningar\nMichael Ländin\nhttp://www.fl-net.se";
$amne="E-postbevakning";
mail("$epost[4]", "$amne", $meddelande, "From: $fran_namn <$fran_email>\nReply-To: $fran_namn <$fran_email>\nX-Mailer: PHP/" . phpversion());
SteveNet - stevenet@webmarkit.net
Cogito ergo doleo.
[Redigerat av stevenet den 11 dec 2000]
woodiMedlem sedan feb. 20001 270 inlägg Och vad exakt är det Du har problem med!?
woodi
Svenska FF1
www.johan-skog.nu
stevenetMedlem sedan juni 20001 251 inlägg Om jag visste det skulle jag inte skrivit ett inlägg här. ;)
Kolla in: http://top100.fl-net.se/uppdatera.php
Cogito ergo doleo.
PhOrPhErMedlem sedan feb. 20002 300 inlägg I ifsatsen på rad 50 (if ($rowdata1[2]=>$rowdata[8])) så har du vänt på jämförelseoperatorerna.
Det borde vara >=
Vad exakt ska detta script göra? Det är krångligt att sätta sig in i det om man inte har en aning vad som ska hända.. :e
- Erik Hellström -
- Datalogiprogrammet - MDH -
- http://3d.burken.nu -
stevenetMedlem sedan juni 20001 251 inlägg Och ändå svårare att förklara.
Cogito ergo doleo.
nanneMedlem sedan dec. 19991 749 inlägg Får du några felmeddelanden?
FÅr du nåt meddelande när du skriver echo mysql_error();
Vad är det som ska hända med scriptet?
"Där ser du. De är synthare och inte scientologer..."
nanne.net
stevenetMedlem sedan juni 20001 251 inlägg Nu kommer det inte upp några felmeddelanden. :) Fast det fungerar inte som det ska.
$tid=time();
$dag=date("w");
if ($vecka=="1") {
$tabort=51;
if ($vecka=="2") {
$tabort=52;
$tid=date("H:i");
if ($vecka=="52") {
$vecka=1;
else {
$vecka++;
if ($dag=="0") {
next;
if ($rowdata[7]) {
else {
$i1=0;
$forsta="";
if ($rowdata1[2]>=$rowdata[8]) {
$i1++;
if ($rowdata[7]) {
else {
$i1=0;
$andra="";
$i1++;
if ($rowdata[7]) {
else {
$i1=0;
$tredje="";
$i1++;
if ($rowdata[7]) {
else {
$i1=0;
$fjarde="";
$i1++;
if ($rowdata[7]) {
else {
$i1=0;
$femte="";
$i1++;
Först läser scriptet in veckan. Det tar sedan bort poster ur vecka som är två veckor gamla. Den lägger även till poster i vecka med nästa veckas nummer. Sedan läses prenumeranter in ur tabellen bevaka (fritext, minst antal röster och 5 kategorier). De tre första sajterna som matchar användarens bevakningskrav listas upp och sammanställs till ett meddelande som skickas ut till användaren.
Nu hoppas jag ni förstår! ;)
Cogito ergo doleo.
