Hjälp med en RSS-läsare
PHP
3 svar · 367 visningar · startad av Bire
Har en läsare som jag vill ha modifierad lite, men jag har noll koll på PHP tyvärr så jag begriper inte hur man gör.. :(
Här är koden:
<?php
/*  PHP RSS Reader v1.1
    By Richard James Kendall
    Bugs to richard@richardjameskendall.com
    Free to use, please acknowledge me
    Place the URL of an RSS feed in the $file variable.
       The $rss_channel array will be filled with data from the feed,
       every RSS feed is different by by and large it should contain:
       Array {
           [TITLE] = feed title
           [DESCRIPTION] = feed description
           [LINK] = link to their website
           [IMAGE] = Array {
                       [URL] = url of image
                       [DESCRIPTION] = alt text of image
           [ITEMS] = Array {
                       [0] = Array {
                               [TITLE] = item title
                               [DESCRIPTION] = item description
                               [LINK = a link to the story
       By default it retrives the Reuters Oddly Enough RSS feed. The data is put into the array
       structure so you can format the information as you see fit.
set_time_limit(0);
$file = "http://www.automotorsport.se/rss/rssgen-nyheter.asp";
$rss_channel = array();
$currently_writing = "";
$main = "5";
$item_counter = 0;
function startElement($parser, $name, $attrs) {
       global $rss_channel, $currently_writing, $main;
       switch($name) {
           case "RSS":
           case "RDF:RDF":
           case "ITEMS":
               break;
           case "CHANNEL":
               $main = "CHANNEL";
               break;
           case "IMAGE":
               $main = "IMAGE";
               $rss_channel["IMAGE"] = array();
               break;
           case "ITEM":
               $main = "ITEMS";
               break;
           default:
               $currently_writing = $name;
               break;
function endElement($parser, $name) {
       global $rss_channel, $currently_writing, $item_counter;
       if ($name == "ITEM") {
           $item_counter++;
function characterData($parser, $data) {
    global $rss_channel, $currently_writing, $main, $item_counter;
    if ($currently_writing != "") {
        switch($main) {
            case "CHANNEL":
                if (isset($rss_channel[$currently_writing])) {
                    $rss_channel[$currently_writing] .= $data;
                } else {
                    $rss_channel[$currently_writing] = $data;
                break;
            case "IMAGE":
                if (isset($rss_channel[$main][$currently_writing])) {
                    $rss_channel[$main][$currently_writing] .= $data;
                } else {
                    $rss_channel[$main][$currently_writing] = $data;
                break;
            case "ITEMS":
                if (isset($rss_channel[$main][$item_counter][$currently_writing])) {
                    $rss_channel[$main][$item_counter][$currently_writing] .= $data;
                } else {
                    //print ("rss_channel[$main][$item_counter][$currently_writing] = $data<br>");
                    $rss_channel[$main][$item_counter][$currently_writing] = $data;
                break;
$xml_parser = xml_parser_create();
xml_set_element_handler($xml_parser, "startElement", "endElement");
xml_set_character_data_handler($xml_parser, "characterData");
if (!($fp = fopen($file, "r"))) {
    die("could not open XML input");
while ($data = fread($fp, 4096)) {
    if (!xml_parse($xml_parser, $data, feof($fp))) {
        die(sprintf("XML error: %s at line %d",
                    xml_error_string(xml_get_error_code($xml_parser)),
                    xml_get_current_line_number($xml_parser)));
xml_parser_free($xml_parser);
// output as HTML
print ("");
if (isset($rss_channel["ITEMS"])) {
    if (count($rss_channel["ITEMS"]) > 0) {
        for($i = 0;$i < count($rss_channel["ITEMS"]);$i++) {
            print ("<a href=\"" . $rss_channel["ITEMS"][$i]["LINK"] . "\" target=\"_new\">" . $rss_channel["ITEMS"][$i]["TITLE"] . "</a>");
            print ("&nbsp;-&nbsp;");
    } else {
        print ("<b>There are no articles in this feed.</b>");
print ("&nbsp;&nbsp;&nbsp;<b>Nyhetskälla: <a href=http://pagead2.googlesyndication.com/pagead/iclk?sa=l&ai=BIgErN2GNQ-LNDL3EiQKWjZ2wBP3jkwqNur-sAcCNtwGgzb4CEAQYBCD8vNkDKAVAwBVIjzlQ-5vrwfv_____AbIBEXd3dy5tb3RvcmZvcnVtLm51ugEKMTYweDYwMF9hc8gBAeABApUCCkJjEw&num=4&adurl=http://www.automotorsport.se&client=ca-pub-4688784803626077>Automotorsport.se</a></center></b>");
Jag vill visa de första 20 tecknen på varje nyhet.
Någon snäll människa som kan ge mig kunskap om det...?
ingen...? :(
Ah, sorry, missat tråden.
<?php
       Array {
           [IMAGE] = Array {
           [ITEMS] = Array {
                       [0] = Array {
set_time_limit(0);
$main = "5";
$item_counter = 0;
       switch($name) {
           case "RSS":
           case "RDF:RDF":
           case "ITEMS":
               break;
           case "CHANNEL":
               $main = "CHANNEL";
               break;
           case "IMAGE":
               $main = "IMAGE";
               break;
           case "ITEM":
               $main = "ITEMS";
               break;
           default:
               break;
           $item_counter++;
        switch($main) {
            case "CHANNEL":
                } else {
                break;
            case "IMAGE":
                } else {
                break;
            case "ITEMS":
                } else {
                break;
// output as HTML
print ("");
        	$str = $rss_channel["ITEMS"][$i]["TITLE"];
        	$num = 20;
            print ("<a href=\"" . $rss_channel["ITEMS"][$i]["LINK"] . "\" target=\"_new\">" . (strlen($str) > $num ? substr($str,0,$num-3).'...' : $str) . "</a>");
    } else {
print ("&nbsp;&nbsp;&nbsp;<b>Nyhetskälla: <a href=http://pagead2.googlesyndication.com/pagead/iclk?sa=l&ai=BIgErN2GNQ-LNDL3EiQKWjZ2wBP3jkwqNur-sAcCNtwGgzb4CEAQYBCD8vNkDKAVAwBVIjzlQ-5vrwfv_____AbIBEXd3dy5tb3RvcmZvcnVtLm51ugEKMTYweDYwMF9hc8gBA  eABApUCCkJjEw&num=4&adurl=http://www.automotorsport.se&client=ca-pub-4688784803626077>Automotorsport.se</a></center></b>");
Tar fram 17 tecken + ... om rubriken är längre än 20, annars visar den bara rubriken som den är.
Tack, funkar klockrent!
269 ms totalt · 4 externa anrop · v20260731065814-full.1dc6f849
126 ms — deklarationer (db)
126 ms — ändringar (db)
